Fitting Nodiz
16 replies to this topic
#1 coopdog
coopdog
  • 4,506 posts
Posted 25 March 2014 - 05:46 PM
can someone make sense of this for me?
The trigger wheel should be mounted to the crank shaft front pulley. The missing tooth should pass the sensor when the engine is at 90* BTDC. It doesn’t need to be an exact 90*, as you will adjust the offset when calibrating the NODIZ. But aim for +/1 10* of accuracy here! Note that many engines, such as the Ford Zetec or Vauxhall C20XE Redtop, already have a suitable crank sensor and pulley arrangement built in, so you can utilise that if needed. If not, here is an example of a crank sensor and trigger wheel fitted to a Ford Pinto engine. This kit is available from us, as well are universal trigger wheels and crank sensors.
thanks
#2 TehMarchant
TehMarchant
  • 628 posts
Posted 25 March 2014 - 06:05 PM
Okay so I guess you are aware that 90^o BTDC is 90 degrees before top dead center
So I would get cylinder 1 to 90^o before top dead center (Piston at the top) and then I guess you put the ring on to line up with the sensor.
I have no idea if that makes any sense to you or not.
Edited by TehMarchant, 25 March 2014 - 06:06 PM.
#3 coopdog
coopdog
  • 4,506 posts
Posted 25 March 2014 - 06:46 PM
to piston 1 right at the top?
then put the trigger wheel with the tooth missing to 90* to the left?
like if it was quarter too on a clock?:L
#4 The Principal
The Principal
  • 763 posts
Posted 25 March 2014 - 07:03 PM
This is the Omex guide but its the same principle, check out page 6 - http://omextechnolog...Manual 2v01.pdf
also this may help - http://www.theminifo...se#entry2910270
Also Piston #1 passes twice for a cycle so make sure your on the firing stroke i.e both valves closed and the rotor arm pointing to number 1 plug or about one o'clock position
edit - also this - http://www.theminifo...megajolt-guide/
Edited by The Principal, 25 March 2014 - 07:06 PM.
#5 coopdog
coopdog
  • 4,506 posts
Posted 25 March 2014 - 10:04 PM
The heads not on yet, would that be a problem?
#6 The Principal
The Principal
  • 763 posts
Posted 26 March 2014 - 08:16 AM
No that makes it easier, put the push rods back in and place a ruler across the top of the rods to check #1 inlet,exhaust are closed (push rods are down) and rotor arm at 1 o'clock.
#7 coopdog
coopdog
  • 4,506 posts
Posted 26 March 2014 - 09:22 AM
I dont have a rotor arm >.< haha
#8 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 26 March 2014 - 10:18 AM
Have a look here:
http://www.autosport...tallation_guide
I know it's not Nodiz but the trigger wheel setup is the same.
#9 coopdog
coopdog
  • 4,506 posts
Posted 26 March 2014 - 02:54 PM
which way does the crankshaft turn on the mini?
#10 coopdog
coopdog
  • 4,506 posts
Posted 26 March 2014 - 05:18 PM
bampppppp
#11 jelboy89
jelboy89
    Formally known as jr4sr4eva
  • 169 posts
Posted 26 March 2014 - 06:02 PM
clockwise
#12 tiger99
tiger99
  • 8,584 posts
Posted 27 March 2014 - 02:09 PM
To set the 90 degree point with the head off is very easy indeed. All you have to do is turn the crankshaft pulley nut clockwise, measuring the heights of pistons 1 and 2 below the top face of the block. When they are equal, piston 1 rising, you are at 90 degrees. A steel rule will do for measuring the piston height, as it is a much more sensitive test than setting to TDC, which requires a dial indicator, and even then is somewhat imprecise.
Why do people have to complicate things?
#13 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 30 March 2014 - 10:35 PM
I just fired mine up with NODIZ this morning. You sorted yet or still need help?
#14 coopdog
coopdog
  • 4,506 posts
Posted 31 March 2014 - 08:21 AM
Not fitted yet, but I think I know what I'm doing now,
What did you end up doing for the crank sensor bracket?
The trigger wheel they sent me is huge!!!
#15 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 31 March 2014 - 11:20 AM
I got a mini specific bracket kit. It had sensor, coil pack and trigger wheel brackets.
