Rear Hi/lo & Cones....popping Out When Car Is Set Low
6 replies to this topic
#1 felixy69
felixy69
  • 186 posts
Posted 26 March 2014 - 01:57 AM
seems like i am having problems left right and center
now when i set my hi/los at a lower setting, the cones seems to pop out when i hit a large bump
i have to jack the car up and reset it
any ways to eliminate it from popping out when i set the car at a lower setting ?
is this where (Shorten) shocks come into play ??
please help
thanks
#2 timmy850
timmy850
  • 3,375 posts
  • Local Club: MITG
Posted 26 March 2014 - 02:40 AM
Shorter shocks are good, you can also get lowered shock brackets for the front
#3 Ethel
  • 26,027 posts
It is, though replacing the rubber cones could be a more effective solution if the lack of travel is because they're old and hard.
#4 felixy69
felixy69
  • 186 posts
Posted 26 March 2014 - 05:41 AM
hummm.. my peoblem isnt rhe front....
it is the rear
if i change to springs ..... are there bolts to hold the springs in ?
#5 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 26 March 2014 - 07:17 AM
I had the same trouble with my 1977 Clubman, so I got Gaz Shocks in UK to make me a custom set for the rear. 10 inches fully compressed, 14.5 inches fully extended. This cost me 50 GBP plus freight. This stopped my HiLo from disconnecting from the rubber donut when fully extended. Their email is technical
@gazshocks.com
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 26 March 2014 - 07:26 AM
it is the rear
No, depending how long you go, you need shocks to match.
I run minitastic springs, with gaz lowered shocks. Never had any issues with the springs popping out etc, because its been installed properly.
Jack the car up, let the radius arm hang down, you will see the trumpet (hi lo) coming loose with the cone. Adjust the hi lo HIGHER so that even at full droop the trumpet is secure with the cone. Your car wont be as low at the rear, but id rather be a little higher and safe. This will prevent the dislodging you are experencing until you get the correct shocks to prevent this. The lowered shocks limit the droop of the radius arm so the hi lo doesnt become dislodged.
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 March 2014 - 07:29 AM
you need something to limit the drop in the suspension, shorter shocks will do this
you haven't commented on the age of your suspension cones from the question above, are they old and hard (lost springiness ) ?
