I re done my primary gear end float clearance and it is spot on now. But I have noticed the the lock 'C' clip can slide out a hell of a lot easier... Surely it can fall out while the crank is rotating?? Or is that not possible??
Iain
Posted 26 March 2014 - 03:05 PM
Iain
Posted 26 March 2014 - 03:40 PM
Posted 26 March 2014 - 03:47 PM
Mine was similar but the flywheel will hold this in place if i am correct.
Posted 26 March 2014 - 05:41 PM
Yeah I suppose it must do, it came off easily in the first place.... So it must hold in place by the flywheel
Posted 26 March 2014 - 07:57 PM
lol, yes the flywheel holds it all together.
Posted 26 March 2014 - 09:03 PM
Not all our brains have this knowledge hahahaha
Posted 26 March 2014 - 09:56 PM
Make sure its position correctly when you fit the flywheel so the C clip cant drop as the flywheel goes on
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
