Stripped Heal Board Threads
2 replies to this topic
#1 GraemeC
GraemeC
  • 7,438 posts
Posted 09 June 2006 - 07:49 AM
Bu66er! I thought I was onto a winner when the bolts came out in tact when I removed the rear subframe, however on reassembly one of the captive nuts in the heal board has stripped.
Suggestions for repair? Don't want to have to weld in a new panel as the shell is all nice and newly painted!
My two thoughts so far are -
1) Drill hole in box section inside car large enough to get a nut and a spanner in (may need longer bolt through subframe mount). This shouldn't be too difficult as I have no rear pockets etc in the way anymore.
2) Re-tap the nut to mate and use a socket head cap screw (I think a normal mate bolt head would be too large to sit against the subframe mount effectively).
#2 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 09 June 2006 - 07:57 AM
I would go with option 1...
you could re-tap the thread but it can be a pain in the butt..
If you have no bins anyway then a little flap for access is all you need.
there was a post on here about it..
http://www.theminifo...l=subframe bolt
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 June 2006 - 08:04 AM
What I've done before, with a pretty good success rate is...
Using a punch, smack the captive nut into the sill, and then enlarge the hole using a hex shaped punch allowing enough roon to put a new 5/16" UNF nut in the hole. weld it in, and grind flat...
