I'm putting a new engine in a mini and it has an electronic dizzy with two wires coming out instead of 1, a white one and a white one with black stripe does anyone know how to wire this and do i need a different coil?
Electronic Dizzy Wiring.
Posted 29 March 2014 - 07:10 PM
Posted 29 March 2014 - 07:16 PM
Posted 29 March 2014 - 07:21 PM
cheers. nice and straight forward
Posted 29 March 2014 - 07:32 PM
Posted 30 March 2014 - 12:27 AM
No problem, if you have an extra white cable on the + coil thats your rev counter leave it there so you might have ignition feed in, positive feed to you elec ignition module and the rev counter trigger all on the + terminal. Just the black with white tracer to - or cb depending on the coil marking.
Not quite. Tach sense wires connect to coil (-) so they can detect the swing between 0V and 12V. A second white wire on coil (+) would be a 12V supply for another component, typically something like an electric fuel pump.
Posted 30 March 2014 - 08:21 AM
Posted 30 March 2014 - 02:15 PM
I can only confirm Lucas wiring through probably the late 1970s. The wire between the distributor and coil was typically white/black. White/black was also the color of the tach sense wire used on RVC type Smiths tachs. Earlier RVI tachs are wired very differently (in series with coil power) which I won't get into here. White wires were typically run to the coil (+) terminal for 'standard' ignition systems. Ballast ignitions had a white/pink (pinkish) wire to coil (+) along with a wire between the starter solenoid and coil (+).
In common Lucas wiring schemes, white wires are un-fused, switched 12V.
Posted 30 March 2014 - 02:39 PM
The Haynes diagrams are terrible mainly concerning the items numbered as the wrong components!
Posted 30 March 2014 - 03:08 PM
Later wiring diagrams are sometimes difficult. The early diagrams which look like they were hand drawn are not that hard to trace and follow. Though there are some later Range Rover and Jags over here, cars like the Mini stopped being imported to the U.S. around 1970 and MGs/Triumphs only made it about another 10 years. That means I seldom have to look at "modern" wiring diagrams for anything newer than 1980.
