Wont Start!
41 replies to this topic
#31 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 02 April 2014 - 05:57 AM
If the breakdown guy said the coil is fudged, I would replace it and see what happens..........
#32 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 02 April 2014 - 07:56 AM
Hmmm I'd check the charging voltage before you do much else - unusual for a battery to cook up and split like that.
how do i check this?
#33 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 02 April 2014 - 12:44 PM
You'll need a basic multimter - select DC volts, range 0-20 ish, start the car and run at a fast idle - voltage should stabilize at somewhere between 13.8 and 14.2 volts, much above that and you have issues with blowing the electrolyte out.
#34 Moggyton
Moggyton
  • 1,152 posts
Posted 02 April 2014 - 04:46 PM
But thats my problem, the car wont start :P
#35 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 02 April 2014 - 10:26 PM
Ah but the problem is which coil to replace it with!
#36 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 03 April 2014 - 02:16 AM
It's pretty simple to test the coil - it's been detailed above. If you do have a simple electronic ignition module it could be fried too.
#37 Moggyton
Moggyton
  • 1,152 posts
Posted 03 April 2014 - 04:34 PM
Right so theres no spark at any of the plugs, does this mean my coil has gone? The coil gives out 12v and roughly 10v when cranked. The coil is a lucus dlb198 so could this be the wrong coil? Thanks again for the help all.
#38 Austin mini 30
Austin mini 30
  • 332 posts
Posted 03 April 2014 - 07:23 PM
check the vaccum pipe from the carb to distributor as well
#39 Badboytunes
Badboytunes
  • 1,615 posts
Posted 04 April 2014 - 05:50 AM
That wont stop it from sending a spark to the plugs tho.....
#40 Badboytunes
Badboytunes
  • 1,615 posts
Posted 04 April 2014 - 05:54 AM
Not sure if mentioned or if you have replaced the dizzy cap or not......
If you have not replaced the dizzy cap, check on the inside of the cap and look at the centre of it ( where the contact points are. )  There should be a small pick up that rests on the rotor arm. Its sits in the middle of the cap and rests in a spring. If this is missing then there will be no spark to the plugs. I dont have a pic to show, hope that makes scence.
If you have replaced the dizzy cap, ignore. lol.
#41 Moggyton
Moggyton
  • 1,152 posts
Posted 04 April 2014 - 06:40 AM
I will look later, thanks
#42 Badboytunes
Badboytunes
  • 1,615 posts
Posted 04 April 2014 - 07:09 AM
Here you go.
Attached File  cap.jpg   191.06K   1 downloads
The bit in the centre of the cap must be present
Edited by Badboytunes, 04 April 2014 - 07:09 AM.
