Charging Problems :(
31 replies to this topic
#16 PetePinnington
PetePinnington
    Formally known as PPinno
  • 367 posts
Posted 02 April 2014 - 06:54 AM
Ok did that alternator test and It does seem to be the alternator. I'm going to borrow my brothers alternator tonight and give that a try just to be 100% sure.
#17 PetePinnington
PetePinnington
  • 367 posts
Posted 03 April 2014 - 01:19 PM
Well, last night I borrowed my brothers alternator which I knew worked. Still wasn't working though. Turns out it was from where I wired up my acewell speedo! Didn't think anything of it at first as there are earth wires coming from the acewell. But I guess the brown and yellow wire wasn't earthed from these wires. Connected it back up to my old two clock speedo which is still in the car (for the temp gauge as I haven't got round to sorting that out yet) and bobs your uncle. All charging now :D thanks for all your help! Mucho aprecciated :)
#18 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 April 2014 - 01:57 PM
The brown/yellow isn't meant to be earthed!
#19 PetePinnington
PetePinnington
  • 367 posts
Posted 03 April 2014 - 05:26 PM
Oh is it not? I don't understand why it works in the old speedo then? All that's wired to the back off that is the panel lights, temp gauge, an earth, and now the ignition light
#20 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 03 April 2014 - 05:47 PM
The clue here may have been the old dash ignition light was feeding the exciter circuit through the bulb to the alternator, no 12v ignition light = no charge same as if the bulb blows
#21 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 April 2014 - 09:01 PM
I think you need to read one of Kernow's excellent threads about how the no charge warning works.
#22 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 03 April 2014 - 09:05 PM
Its here to help pinpoint the fault were discussing http://www.theminifo...g-how-it-works/
#23 PetePinnington
PetePinnington
  • 367 posts
Posted 03 April 2014 - 09:31 PM
Ahh ok I think I have it, there is a white wire in the back which I had forgotten about. So for the battery to charge, the white ignition wire needs to be connected to the bulb which is then connected to the brown and yellow? My acewell speedo only has one wire coming out for the warning bulb. How do I go about wiring this up or would the only option be to source an external bulb and mount it somewhere else on the dash?
#24 PetePinnington
PetePinnington
  • 367 posts
Posted 03 April 2014 - 09:32 PM
And that is an excellent thread! Wish I had seen it before!
#25 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 03 April 2014 - 09:42 PM
As long as the exciter wire is connnected up and fed in he same manner as in the article then yes, some kit cars use a seperate charge light.
#26 PetePinnington
PetePinnington
  • 367 posts
Posted 03 April 2014 - 09:55 PM
Okie dokie, I can't see a way of wiring it up to the acewell so I'll just use a seperate light. I've got a few of these kicking around, will it be ok to use on them? 7411146bfc009adc3af429560f98b69e_zpsdc2d
#27 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 April 2014 - 10:56 PM
Which Acewell is it?
#28 PetePinnington
PetePinnington
  • 367 posts
Posted 04 April 2014 - 06:42 AM
It's the 3973
#29 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 April 2014 - 07:10 AM
How did you wire it? Brown/yellow directly to the green pin in the multi plug for the lamp would be the right way, but the lamp is an LED which is the real problem. The circuit needs to flow around 2.2 watts straight off the ignition switched supply. Even if the lamps are replaceable you won't know if it's up to the job of carrying enough current internally or if it's wired right. You could make it work but it would mean surgery to the unit. Alternatively you could use a resistor and a diode protected relay. If the resistor and relay coil together had the right resistance to make the alternator work, they would be doing the functional job of the warning lamp in the circuit. The relay would then be driving the warning lamp in the cluster. It would be very much an on/off switch though and you wouldn't get a warning of minor under voltages as you do with the lamp.
#30 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 04 April 2014 - 07:32 AM
As usual uncle Kernow provides top info. Worth reading the article though as the alternator fitted is capable of both machine and battery sensing.
