Ht Lead Length
3 replies to this topic
#1 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 01 April 2014 - 11:55 AM
the HT leads on this Mini of ours seem to be very long (twice the length they should be) -
1- 50cm
2 - 45cm
3 - 38cm
4 - 38cm
centre king lead - 38cm
They are looped up and cable tied to each other.
We are trying to eliminate a spark issue, could the length of the wires be causing poor sparks?
Should I cut them down or is it best to buy new ones?
Has anyone used these?
http://www.ebay.co.u...=item2a37909f2d
#2 Cooperman
  • 23,309 posts
Posted 01 April 2014 - 12:11 PM
The very best way to sort out Mini ignition is to buy a length of copper-core HT cable from someone like AES Ltd. Then buy a set of screw-on plug caps and distributor end connections (unless it's a very early type distributor). Cut the HT lead to the right length for each plug, fit the new ends and it will work fine and look right with no unnecessary length so it will be tidy.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 01 April 2014 - 12:28 PM
+1 on Cooperman's advice.  Homemade solid core wires with resistor terminal/plugs can make the wiring very neat and is a satisfying project in its own.
#4 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 01 April 2014 - 01:23 PM
Those leads will be good.. The company are great.. I ordered on sunday and the parts arrived today
