Does The Underbonnet Sound Proofing Work?
7 replies to this topic
#1 BillyTheHobbit
BillyTheHobbit
    Just On Tickover
  • 9 posts
Posted 02 April 2014 - 07:15 PM
Hi Guys,
My leyland Mini 850 is pretty loud and can give you quite a head ache on long journeys,
I know that this is very common, little motor working hard.
But was wondering how much of a difference the underbonnet soundproofing makes.
I know that I can also get some for the bulkhead but dont want it to soak up water and cause rust.
Will it make much of a difference on its own?
Tom.
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 02 April 2014 - 07:18 PM
In a word, No. There isn't much you can do to make a mini truly quiet but just the under bonnet won't do a lot at all.
#3 BillyTheHobbit
BillyTheHobbit
    Just On Tickover
  • 9 posts
Posted 02 April 2014 - 07:20 PM
Cool thanks,
Im used to it but my friends certainly aren't.
#4 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 02 April 2014 - 07:30 PM
i fitted it and i found it did dull the sound, above 40 tho doesnt do much but around town its nicer. the bulkhead one will be good. put more in the floors, bootlid, and interior bulkhead to get it even quieter. there is a thread on here about it somewhere
#5 1984mini25
1984mini25
  • 8,784 posts
Posted 02 April 2014 - 07:34 PM
I've never really bothered with under bonnet sound proofing, but instead tried to stuff as much carpet underlay behind the dash, lower bulkhead and carpets as possible.
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 02 April 2014 - 07:35 PM
Check for holes in the exhaust
#7 mingy
mingy
  • 930 posts
Posted 02 April 2014 - 07:44 PM
Don,t bother soundproofing under the bonnet, it does not make any significant difference to noise levels in the car but without it, it allows  more heat dissipation from within the engine compartment on warm days and ( tongue in cheek ) you may gain an extra 0.005 bhp due to weight loss !!!!!!! Lol
#8 tiger99
tiger99
  • 8,584 posts
Posted 03 April 2014 - 09:13 PM
I do believe that a MODERN sound proofing material under the bonnet will make a useful difference. Some of the more traditional materials merely trapped water and caused rust. Some of the stuff that looks like aluminised bubble-wrap is both a sound and heat insulator, and should achieve useful results if the bulkhead is properly covered, which means having the subframe out.
I also noted many years ago that a standard (in those days) traditional sound insulation kit had 4 triangular pieces which were glued to the bonnet, between the stiffners, and those definitely do damp certain resonances, and make a slight, but worthwhile, difference.
But making the Mini quieter needs a comprehensive approach, giving attention to damping panel resonances, which means replacing the bitumen pads (possibly with something similar but better) that are usually removed for floor repairs etc.
