Posted 10 June 2006 - 06:56 AM
You shouldn't need any spacers with the 7" x 13" rims. If your car had disks fitted as OE then you should have the pre-spacered rear drums anyway. I have the standard hub/drum setup with 7" x 13" Superlites and I temporarily shod them with group 2 wide arches from Minisport (which are similar size to Sportpack arches really) and they just covered the tyre. There are a few people on here that have used 7 x 13s with Sportspacks if you have a look through the projects section, you could ask em if they have used spacers, but I reckon none of them will have as this size wheel will fill the arches nicely anyway.
