It took longer to get the old rusty bolts out from the original hinges than it did to install these. I used rivnuts in the inner wing to attach them so if I need to I can remove them. They work great, if you work on your car under the bonnet these are a must. No more crowning your head on the the catch.
With the Minivation Hinges.
Using the prop rod.
A crappy phone camera shot of the hinge.
