Hi was just wondering if i've fitted my 6 bladed fan on the right way round.
If I fit it the other way it will hit the crank case breather.
Josh
Posted 07 April 2014 - 06:18 PM
That is the wrong way round.
Posted 07 April 2014 - 06:24 PM
Edited by Dan, 07 April 2014 - 06:34 PM.
Avoiding the swear filter
Posted 07 April 2014 - 06:37 PM
Posted 07 April 2014 - 06:59 PM
I have fitted the rad lol.
I'm using a round breather, don't really want to change it as its all sealed up now lol
Posted 07 April 2014 - 07:12 PM
The mod involves either pounding the round side of the breather flat near the fan or... I have seen where people cut the interfering area off and weld a flat plate over the cut-off area. Fit the radiator and check the fan to radiator clearance first as Dan suggested.
Posted 07 April 2014 - 08:08 PM
ok..
I have turned it round, and it clears the breather with the fan spacer.
But now it fouls the rad at the top. I tried to use a smaller spacer (cough some nuts) which it still clears the breather but still fouls the rad.
Is this a common problem? I've tried it with no spacer but it hits the breather!
Any ideas would be great! :)
Posted 07 April 2014 - 08:12 PM
You could 'adjust' the fan blades, but it seems as thought you will need to alter the breather.
Posted 07 April 2014 - 08:24 PM
it's so close to clearing the breather with no spacers! How much more room does the cases with flat breathers give?
I think this might be the easiest way out of this one lol
Posted 07 April 2014 - 08:28 PM
or modifying the one I have looking at the prices of new ones!!lol
Posted 07 April 2014 - 09:08 PM
Fitting a fan must be done correctly. You are supposed to have the 'flattened' oil breather can and without that it can be a problem.
Remember, the Mini cooling system is a 'ducted fan'. The centre of he fan blades must be in line with the lip of the fan shroud and the clearance around he shroud to the blade tips must be constant. This is key to the correct amount of air being pushed through the radiator.
You may have to flatten the 'pot' to achieve this.
Posted 07 April 2014 - 09:28 PM
I have a cover that came with the engine. It doesn't have a canister on it, just as metal pipe coming out at 90 degrees. It has a small crack which I can weld up so it won't leak. I'm going to vent the breathers to air with a small oil breather filter thing. This would give me plenty of clearance so no spacer is needed.
Is it ok not to have the canister have to be used?
Posted 07 April 2014 - 10:39 PM
Posted 07 April 2014 - 10:47 PM
You could delete the 'can' and use an oil 'catch tank' under the front wing with a hose going from the stub breather pipe to the catch tank. that is what a lot of race & rally cars use.
Posted 08 April 2014 - 06:39 PM
