Running No Thermostat?
9 replies to this topic
#1 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 07 April 2014 - 06:46 PM
My mini seems to run very hot ( recent 1330 rebuild ) but not boil a couple of people said try it with no thermostat a friend of mine had a similar problem and ran without a thermostat with no issues for years, are there dangers of running no thermostat?
Edited by cian, 07 April 2014 - 06:47 PM.
#2 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 07 April 2014 - 06:50 PM
Not good without a thermostat because number 3 & 4 cylinders will get very little coolant flow, the water pump will only pump water through the thermostat end and back into the radiator, either get a new thermostat or at least use a blanking sleeve.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 April 2014 - 06:52 PM
Yes, it can lead to hot spots in the engine around cylinder 3 and 4 because even if you fit a sleeve it changes the coolant flow through the block. It will also make the engine take longer to warm up, and removes all temperature regulation. Thermostatic cooling was a major advance in engine design.
In the 1930s.
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 07 April 2014 - 06:54 PM
Is it running hot on the gauge? Is the gauge correct?
Is the mixture right? Timing correct?
IT's better to fix the cause than the effect!
#5 jaydee
jaydee
  • 8,565 posts
Posted 07 April 2014 - 06:56 PM
You can just drill two 1/8'' holes in the thermostat. Dont run without one.
But as above, fix the cause rather than tampering the effect..
#6 cian
cian
  • 869 posts
Posted 07 April 2014 - 06:57 PM
The engine does need tuned since the rebuild and the plugs are very white but i was told a leaner mixture is better for running in, the temp sender was changed and it reads almost 120c
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 07 April 2014 - 06:58 PM
lean mixture will make it run hot
#8 cian
cian
  • 869 posts
Posted 07 April 2014 - 06:59 PM
Im just trying to cover all the bases
#9 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 09 April 2014 - 11:47 AM
Was the engine properly flushed out during/after the rebuild, could there be debris inside restricting water flow? Might be an idea to back flush the radiator too.
#10 cian
cian
  • 869 posts
Posted 09 April 2014 - 12:29 PM
I flushed the rad 2 or three times, did not flush the engine, i take it run the garden hose down the thermostat housing?
