998 Turbo
Posted 07 April 2014 - 07:14 PM
Posted 07 April 2014 - 07:22 PM
Use a T2 (renault 5) instead of the T3, it will fit dead easy
Did you work out the correct CR to run forced induction? Its the case where a 12g940 head will need a bit of chamber reshaping..
Fitting a 940 to a 998 is dead easy aswell, if you're able to pocket the block or recess the exhaust valves. This has been covered few times on the forum, just do a quick search. As a rule of thumb, a standard lift cam will allow the fitment of an old leaded 940, most unleaded will require the valves to be recessed about 40 thou. You'll need to pocket the block if you got an high lift cam instead.
Posted 07 April 2014 - 07:37 PM
Posted 07 April 2014 - 09:19 PM
And with the decompression plate a lot of people see it as a bad thing, but give it ago of you want, a lot of people have run on with no problems, but you do need to take in the cc for the two extra gaskets you need to fit in too!
Posted 07 April 2014 - 09:20 PM
Posted 08 April 2014 - 07:44 AM
Posted 08 April 2014 - 08:11 AM
Why would it take ages to boost on a 998? Would it just be better to put it on the 1310 I have ? However it needs £700 worth of work on it
Because it's a small engine and a big turbo :L
Just buy at t2 or a g15
Posted 08 April 2014 - 08:16 AM
