This came with a Metro turbo engine i bought but i am using a larger GT17 turbo.
It is a hybrid of two turbos a Renault 5 T2 exhaust housing, bespoke core with big pad 360 degree thrust bearing and a GT15 Espace compressor housing which gives nice and easy intercooler pipe access. It should take 18-20 psi (according to the guy who had it built) and make good power.
Would make a nice little turbo for a 998, but would also make a nice turbo for a 1275 would boost very low down but it may strangle it a bit at higher revs.
It seems to have had very little use no play in the shaft. I have a downpipe flange for it so you can make up your own downpipe. I have already flipped the actuator tab so it clears the bulkhead.
Actuator is included with the turbo.
Looking for £150 ONO postage will be around £10 at a guess.
I will get some photos uploaded tonight.
I also have the mirage exhaust manifold to fit this turbo for sale which lets you fit the turbo without any bulkhead modifications.
Thanks.
Nick.
Edited by Nick Warwick, 08 April 2014 - 12:32 PM.
