Urgent Manifold Help!
18 replies to this topic
#1 doormatt
doormatt
  • 233 posts
Posted 09 April 2014 - 04:17 PM
Right so due to the standard exhaust on my car being so old and broken that it is now unusable I have bought myself a brand new straight through centre exit twin DTM pipe with an LCB manifold. As I am new to minis I did not realise that the exhaust manifold and inlet manifold were joined on the original system so I did not order a new inlet manifold. I asked a friend who has plenty of experience with minis and he told me to get the water heated inlet manifold from minispares which I have just ordered. What I am not sure about is what the two black pipes which stick out the side are for, and if they are water pipes. I don't think my current inlet manifold has water pipes so what do I do?
I am doing this work at a friends garage but I'm going away next week so I need to get it done ASAP as I can't leave my car there for a week.
#2 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 09 April 2014 - 04:27 PM
They are water pipes and they require plumbing into the cooling system to function.
I assume you can leave them disconnected though if you want to use the car straight away. Not sure its truly necessary in this country to heat the manifold. Someone will confirm or pour scorn on all of this im sure :-)
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 09 April 2014 - 04:34 PM
Some people connect them but most don't. Just bypass it and there is no problem.
#4 beaker the muppet
beaker the muppet
  • 13 posts
  • Local Club: KLMC, Wigton
Posted 09 April 2014 - 05:01 PM
yeah makes sense, those are just for heating the inlet manifold, given that the days are significantly warmer now it won’t make any difference if the manifold is heated or not.... i think
if your mini doesn’t have heated manifold at the moment then just fit the new manifold and ignore the heating pipes until you have a chance to sort it out properly.
#5 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 09 April 2014 - 05:06 PM
I had them not connected with no ill effects. When after 3 years I decided to plumb them in, now the choke needed for very short time only. I think, if the manifold has been designed to have water cooling, it certainly performs better when plumbed in.
#6 doormatt
doormatt
  • 233 posts
Posted 09 April 2014 - 05:07 PM
Thanks guys
#7 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 09 April 2014 - 05:30 PM
It's not designed for water cooling, it's for water heating the fuel/air mixture.  It had been discussed two or three times in the short time I've been on TMF.
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 09 April 2014 - 05:55 PM
Indeed it has and the main thing that seems to get heated is the discussion. What most people seem able to agree on is that it doesn't make a great deal of difference either way.
OP- if you want to know more on the pros and cons just do a quick search and as MM says there are a few threads.
#9 klivins
klivins
  • 317 posts
Posted 09 April 2014 - 08:19 PM
I would tend to think it can do both, heating and cooling. For instance, if on hot day steaming uphill, your exaust manifold can be red hot, and transfer its temperature to nearby inlet manifold (esp. on standart setup). Having manifold plumbed in water cooling system makes manifold and carb very stable temperature wise.
#10 Cooperman
  • 23,513 posts
Posted 09 April 2014 - 08:26 PM
To change the subject slightly, I hope the OP realises that a twin exit DTM exhaust will lose him a few bhp. Not exactly the ideal design of exhaust when compared to performance exhausts like the Maniflow or RC40.
#11 Gremlin
Gremlin
  • 2,142 posts
Posted 09 April 2014 - 08:56 PM
To add you may want to alter the fuelling and timing
#12 doormatt
doormatt
  • 233 posts
Posted 10 April 2014 - 07:25 AM
Yeah I've realised about the fuelling and timing. And I'm not too bothered about the slight power loss, I got the twin DTM for its looks and sound. And I guess the verdict is that I don't need to worry too much about the two pipes
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 10 April 2014 - 09:50 AM
Leave them off permanently, the coolant takes a while to warm up and the exhaust manifold heat will radiate up anyway
#14 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 10 April 2014 - 10:06 AM
Not everyone wants 100% performance from everything.
#15 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 10 April 2014 - 10:15 AM
Or do this to it:
IMG_20140315_122539_zpsofgugrm_edit_1394
