Wont Start After Carb Rebuild.
Posted 10 April 2014 - 09:18 AM
Posted 10 April 2014 - 09:28 AM
Pour a thimble full of fuel down the carb, then try to start it. If it starts you've got a fuel problem.
Float sticking closed possibly?
Posted 10 April 2014 - 12:18 PM
As above, start with the thimble of fuel test to confirm that the non-start issue is related to the carb and not something else.
You rebuilt the carb. Did you set the float valve height proplerly, make the initial re-start jet adjustments, insure the piston was free to move, re-plumb the carb properly when re-installing it, connect or cap all the connection points on the outside of the carb, fit new manifold gaskets and make sure everything is seated, properly connect and adjust the throttle and choke linkages?
Posted 10 April 2014 - 12:46 PM
Posted 10 April 2014 - 12:50 PM
Posted 10 April 2014 - 02:47 PM
Posted 10 April 2014 - 03:40 PM
Posted 11 April 2014 - 11:11 AM
Posted 11 April 2014 - 11:39 AM
Check the leads are on in the correct order
Posted 14 April 2014 - 12:03 PM
When I go to turn the key over its kind of sounding like a backfire but won't fully ignite. I'm baffled as to what it could be. I've checked points, timing, float level and its moving freely. It's got a spark and now battery power. Also has fuel. I'm stuck
Backfire out the carb or the tailpipe?
If you did not touch the timing, you have rebuilt the carb, and the backfire is out of the carb, look for fuel supply issues. The quick sanity check is to dump a thimble of fuel down the carb throat and try to start the engine. If it fires briefly then promptly dies, you have a fuel delivery problem.
