Running Rough
2 replies to this topic
#1 smudgersmith
smudgersmith
  • 102 posts
  • Local Club: not yet
Posted 10 April 2014 - 09:26 AM
hi all i have a mafair 998
my problem is it runs rough back fires through carb has no power from tick over upto about 2500rpm
has had new sparkright ignition system including coil distributor new leads plugs set the ignition timing
has had head rebuild has 200 compresion on all cylinders valves dont stick all the gaps are correct
hs4 carb rebuilt standard needle
has standard airfilter 3 inch exhaust
oil in dash pot
but still runs like crap lol help please
Edited by smudgersmith, 10 April 2014 - 09:27 AM.
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 10 April 2014 - 09:48 AM
Will be running lean
#3 smudgersmith
smudgersmith
  • 102 posts
Posted 10 April 2014 - 09:51 AM
just had a look on line and realised it has the dashpot damper off a hiff38/44 might be the problem ?
