Ive been having trouble with my 1293 turbo engine. I'm using a grey-diaphragm, pre verto clutch assembly.
Firstly, with the engine in the car but not running, with my foot on the clutch I cannot spin the engine over on the starter motor. Secondly, with the engine ticking over at about 1,000 rpm, if I were to put my foot on the clutch, it stalls/stops the engine running.
I now have the engine out of the car and with the gearbox and clutch off I have measured the end-float of the crank. Putting a feeler gauge between the centre main crank web and the thrust I am getting 0.1mm (I think this is 4 thou in old money?) Haynes manual recommends between 0.05mm and 0.076mm, so do I have too much and could this be the cause of my earlier explained issues? The thrusts look to have been installed in the correct way around.
I am a little confused as to what is too much, some people are saying more than 3 thou is bad, some are saying anything under 10 thou is fine?
The engine will be pretty high power but its not going to be doing more than 1,000 miles a year.
If this is fine, what else could be the cause to my issue as stated above? The clutch assembly looks like it was put together correctly, transfer gears and main gear set looks good too.
Help!! Thanks!
