Engine Cuts Out When Reversing
10 replies to this topic
#1 MiniHead95
MiniHead95
  • 168 posts
Posted 16 April 2014 - 09:08 AM
Hello  :proud: In the past couple of days for an unknown reason when I start to reverse the car after about 1-2 seconds nearly cuts out I have to save it by planting my foot on the clutch..  :mmkay: Doesn't matter if I rev quite hard or just the normal amount it still goes to cut out. When and if it does it isn't like it is stalling as it doesn't lurch at all, the revs just drop and if I don't try and save it with the clutch it just dies and I have to start the engine again!  :goaway:  So yeah if anyone has experienced this or knows anyone who has and knows something please help haha, cheers all  :proud:
#2 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 16 April 2014 - 10:28 AM
Seems odd.  Are you sure it's only in reverse or when you're slowly manouvering in either direction?  It might just manifest itself when you're going backwards because you're going so carefully?
#3 MiniHead95
MiniHead95
  • 168 posts
Posted 16 April 2014 - 10:41 AM
Hello, no I can crawl along in first and it's fine, literally just inn reverse  :shifty:
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 16 April 2014 - 10:48 AM
You say it's not like it's stalling, is it like you've turned it off? And if the clutch is depressed soon enough it picks up and carrys on running fine
#5 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 16 April 2014 - 11:20 AM
Check your rear brakes are not binding
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 16 April 2014 - 11:25 AM
Air leak, possibly not an issue when going forwards, but reverse force might be causing a gap to open, air leak and cut engine.
#7 classicoop
classicoop
  • 182 posts
Posted 16 April 2014 - 11:55 AM
+1 on air leak.
Could also be wiring, something getting pulled. Happened to me, wiggled the wiring, never happened again.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 April 2014 - 12:06 PM
short on the reversing light cutting power to the coil
try disconnecting the switch under the gear stick
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 April 2014 - 12:19 PM
+1 on reverse light switch.
If you have a tach installed in your dash, watch it as you try to back up.  If the tach needle drops like a stone, that is an electrical issue.  If the tach needle coasts down to zero, something mechanical is at fault.
#10 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 16 April 2014 - 12:48 PM
Hmm, he can save it with the clutch so the money may be on engine movement causing something to open up.
#11 MiniHead95
MiniHead95
  • 168 posts
Posted 18 April 2014 - 04:41 PM
I will give this a go at some point and let you know if it makes any difference  :proud:
