Please bear with me as I’m not well versed at auto-electrical terminologies. I was trying to connect a 12v cigarette lighter type socket to my 1996 Mayfair SPi to use for my SatNav & possibly charging my phone. The method I employed hasn’t quite worked . It has also made me even more confused as to what’s now happening. Basically I’ve read through a number of the previously listed Lighter threads to get some info on how to do this, but so far none of them seemed to apply to my SPi. I looked behind & under the dash for ‘brown’ or ‘green & yellow’ wires. I was met by a jungle of multi-coloured wires where none of them matched what most people have been saying to wire the component to.
However, after finding what appeared to be a separate bunch of 3 wires connected to disused plug tucked behind the passenger air vent under the dash (*See Photo1), I used a voltage meter to test which one had power coming through to it. This bunch has a solid black, brown/black and white/black wire. The white/black wire gave a reading of 11.8 volts. This was without the key on. So I proceeded to wire it up adding a 20A inline fuse as recommended (*See Photo2) to the positive red on the socket. I attached the black negative one to an existing earth point on the bodywork next to it (*See Photo3).
NOW, THIS IS WHERE THINGS GET INTERESTING....
I plugged in an FM Mp3 Transmitter and it didn’t power up. I then plugged in my Samsung phone charger, no sign of charging. I then plugged in a friend’s HTC phone charger & the light on the charger came on. The charging icon on his phone was flickering. When I ran the engine, the flickering icon stabilised slightly, but still flickered. I then used the voltage meter on the inside of the socket to see if any power was coming through. I was still getting a constant 11.8v reading. I then plugged in my TomTom, again the charger showed a green light, but still no power to the TomTom! Checked the earth was connected properly, no change. Since then I’ve been getting static electricity shocks when I touch the door. I'm rather confused by it all now.
Obviously something is amiss here. With my inexperience, I don’t know whether I’ve wired it all incorrectly or is the lighter socket itself faulty? Does anyone know what this seemingly unused bunch wires is because everything electrical is still working in the car?
Your help & advice on how to wire it in properly would be most appreciated.
*Photo1: https://farm8.static...b700fd290_c.jpg
*Photo2 : https://farm4.static...4b0d935d5_c.jpg
*Photo3: https://farm8.static...b3f8b52a9_c.jpg
Many thanks in advance
