does it suck through the rad to the engine,
or blow air through the rad at the wheel?
looking at going electric wasnt sure the best way to set it up
Posted 16 April 2014 - 05:39 PM
Posted 16 April 2014 - 05:42 PM
sucks past the engine and blows out through the rad and wing
Posted 16 April 2014 - 06:15 PM
yep blows past the wheel, if you stand by the wheel and have someone rev the engine you can feel the air.
Posted 16 April 2014 - 06:18 PM
The mechanical fan blows into the rad, if you fit an electric fan, it would go on the wing blowing away from the rad (to the wheel)
Posted 16 April 2014 - 06:27 PM
Diagrams of the factory fitted electric fans and aftermarket:
http://www.minispare...6.aspx?2~19~181
http://www.somerford...page=page&id=97
Posted 16 April 2014 - 09:43 PM
Edited by vx220, 16 April 2014 - 09:43 PM.
Posted 16 April 2014 - 09:58 PM
Unless being used for short races, the mechanical fan is essential for reliability. An electric fan is not rated for continuous use, but the Mini needs constant air flow through the radiator.
Posted 17 April 2014 - 08:45 AM
Just wondering why Peter? My mate who does a lot of my engineering is keen to go electric and get rid of the constant fan. Mind you, he wants to put a rad in below the grille so that would be constant airflow.
Posted 17 April 2014 - 09:35 AM
Edited by Dan, 17 April 2014 - 09:35 AM.
Posted 17 April 2014 - 04:55 PM
Ok, I understand that Dan. MPI stylee should be fine though? My mate's thinking GSXR 1100 radiator behind the front valance below the grille.
Posted 17 April 2014 - 07:51 PM
With a side mounted radiator, an electric fan is no gain at all.
For a race car where the fan could be driven from a fully charged battery with no power required from the alternator, it does make some sense, but for a continuously run fan in a road car, the same amount of air needs to be shifted through the radiator to get the heat out, which requires the same amount of mechanical 'work'. Thus the same amount of energy needs to be obtained and this can come from either the mechanical fan of from the alternator, both of which are driven from the crankshaft pulley via the fan/alternator belt.
But, the electric fan is not a 'continuously-rated' item and is thus liable to failure when used continuously. When that happens and there is no mechanical fay, you ain't going anywhere. So reliability would be compromised for a gain which is not evident, especially for road use.
