Auto Box Problem
4 replies to this topic
#1 Det
Det
    Starting My Mini Up
  • 2 posts
Posted 17 April 2014 - 10:43 PM
My 998 auto is having trouble changing from 3rd to 4th.
It gets there eventually but revs like crazy when changing.
Please tell me it is a simple fix.
#2 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 17 April 2014 - 11:05 PM
Hi
Is this shifting in drive or shifting manually from 3rd to 4th ?
#3 Det
Det
    Starting My Mini Up
  • 2 posts
Posted 17 April 2014 - 11:18 PM
Shifting in drive.
#4 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 18 April 2014 - 06:20 AM
Check the length of the dickdown rod - this acts directly on the pump governor, and will change the gearchange points.
#5 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 18 April 2014 - 09:53 AM
just to add, its adjustment is made from underneath the car. The rod has a threaded part that you turn into or out of the arm that disappears inside the gear box housing (after disconnecting the top end from the throttle linkage) That essentially changes the length of the governor control rod which changes the points at which the box changes gear.
Proper setting of this involves locking the bell crank in relation to the gearbox casing using a rod or suitably sized drill bit.
Mine changes into 4th at about 20 mph which seems too slow at times but I believe thats how they left the factory.
Edited by jime17, 18 April 2014 - 09:56 AM.
