The indicators on my daughter's MK3 1976 Mini 1000 don't seem to cancel unless I turn through about 120 degrees. Is this normal or is there something I haven't done, or should do, that will fix it?
Thanks, Paul.
Posted 18 April 2014 - 04:39 PM
Thanks, Paul.
Posted 18 April 2014 - 04:47 PM
Usually the steering wheel boss in wrong orientation. there should be a lug pointing vertical on it.
Posted 18 April 2014 - 04:53 PM
There is a plastic block screwed to the steering column. Should that be pointing vertically when the wheels are straight?
Thanks, Paul.
Posted 18 April 2014 - 05:08 PM
Remove steering wheel, turn black plastic thing 180º, replace steering wheel.
Posted 18 April 2014 - 05:25 PM
Thanks for the replies I'm going to see if I can get my head round that lot and have a look tomorrow.
Cheers, Paul.
