As this crops up and people have the distributor and not the wiring harness, see below the 2 standard types of modules and how to wire then to the ignition system. You could make your own short loom.
Minispares keep the wiring harness with the factory plug here https://www.minispar...|Back to search
The Coil to use is GCL 143
