Window Hard To Wind Up.
Posted 20 April 2014 - 04:58 PM
The problem im having is halfway going up, the glass tilts, very slightly, to the rear and kinda gets stuck, i pull it up and forward, wind it up a bit then just wind it up normally.
Going down = no problems
Going up (anywhere above/below midway point) = a little stiff, but manageable
Going up (midway point) = have to pull glass up.
The winder mechanism is bolted on door securely
This started a few weeks ago.
1yr old rubber
Rails were checked last year, no corrosion.
Did some googling but most talked about corrosion. But i don't think mines corrosion. Although i havent opened it up yet.
Posted 20 April 2014 - 05:23 PM
It could well be corrosion if it was checked last year. Its surprising how quickly it takes hold, especially with bad weather and all of the water that passes through the door.
Other than that my only other guess would be that the gears need greasing up?
Either way,you won't know for sure without removing the mechanism.
Hope its something easy
Ben
Posted 20 April 2014 - 05:25 PM
Or it could be the rails on the bottom of the glass. The channel might have bent slightly allowing movement on the arms. That would explain the glass dropping back. If it is that, then it must be sorted soon or it will get worse and will probably end up with the arm popping off of the channel.
Posted 21 April 2014 - 02:18 AM
Posted 21 April 2014 - 05:42 AM
Posted 21 April 2014 - 06:05 AM
sounds like that ^^^^^^ have the door card off and the mechanism out
Posted 21 April 2014 - 03:52 PM
Posted 21 April 2014 - 04:00 PM
not if the rear of the window is dropping first , that's got to be the bit that's holding the glass in
Edited by Bungle, 21 April 2014 - 04:00 PM.
Posted 21 April 2014 - 04:29 PM
+1
Posted 22 April 2014 - 01:32 PM
