Hi!
I've been building my race Mini for two years. Last weekend I raced it for first time. Everything went perfect but I had problems with brakes.
First, I'm going to list the components:
Minispares GMC227 yellow tag master cylinder with repair kit fitted as KAD told me. Motul RBF600 fluid. No servo.
- Front: KAD 4-pot vented calipers, 7,75" vented discs, C-STR987 carbometallic pads from Minispares.
- Rear: Minisport Minifin drums. No brake limit valve.
Everything is new.
The problem is sometimes the pedal is extremely soft and sometimes is hard, as I would like to be. It's not when hot or cold, it seems random.
After bleeding a lot of times, KAD told me to fit the master cylinder repair kit as some master cylinders are not in perfect condition when new. We bleed again, with Gunson Easybleed and with the traditional method.
The brake pedal is usually soft. Sometimes it goes harder after pressing it 5 or 6 times, but not always. Sometimes it's hard at first time.
If the problem appeared when hot, I would have thought about pads or fluid. But it appears when cold too.
I can't understand this situation so any suggestion will be appreciated.
I'm racing again in two weeks and I would like to finish the race because everyting is perfect except the brakes. Last race I only did 12 laps due to braking problems.
Many thanks and best regards from Barcelona!
Albert
Pd. sorry for my english. If you don't understand anything, I'll try to explain better.
Edited by farres_jr, 20 April 2014 - 05:32 PM.
