I have a CAM 6232 crank and a 12g1505 crank. I'm currently building a 1380, and was just wondering what crank would be best to use?
I understand the 6232 was used in turbo engines, would that make it stronger?
Posted 21 April 2014 - 12:41 PM
Posted 21 April 2014 - 02:29 PM
12G1505
1275cc
Non-S, EN16T with 1.75" dia. big ends
CAM6232
1275cc
Rolled-fillet radius on bearing journals, A+ with 1.75" dia. big ends
they are both standard cranks the question is which is in better condition have you measured the journal sizes either could have been ground a few times.
by the way the 6232 is still available as new
edit - Just found this reference for the 6232 to answer your question - This crankshaft was used in all 1275cc, A+, transverse engines including the MG Metro Turbo. There are various un-confirmed opinions on the subject of whether the material was any different, or whether it was heat treated differently. It would appear that early Turbos had just the standard spec, EN16T, non-heat treated type fitted. Later examples certainly appear to have been heat-treated, probably an up-to-date, emissions-friendly version of 'Tuftriding' (a recognised ICI registered process) - possibly a forerunner to Nitro-Carburising. These crankshafts have a distinctly charcoal-grey/black finish - mostly detectable on the webs, water pump/alternator pulley end and in the rolled fillet radii. The later being fairly 'deep' and very even. - http://www.calverst....roductionID.htm
Edited by The Principal, 21 April 2014 - 03:44 PM.
Posted 21 April 2014 - 03:24 PM
Posted 21 April 2014 - 04:18 PM
Thanks a lot for your help guys. So what ever one is in better condition I should keep and use?
