Hi all,
Fairly new to the world of Classic Mini's. I imported a JDM model this winter, and she's sat since January, and I noticed I've developed a leak. It looks like it's leaking both coolant and oil, but it's been hard to confirm. I keep checking the oil level, but it doesn't seem to go down, whereas the coolant needs to be topped off every few weeks. I finally found some time to crawl under the Mini, and take a look at a few things (as I think the cones need replacing as well), but I couldn't quite confirm where the leak was coming from. Based on my reading, it seems that it's quite common for these cars to leak.
I found a small bit of coolant up by where the radiator fan meets the engine, but the bottom of the engine seemed to be covered in old oil. I tried to clean it up a bit, but the leak isn't fast enough to determine where it's coming from. I've included some fairly crappy pictures.
This one is looking up at where the coolant seems to be coming from.
This one is the bottom of the motor. I had to drive through a wet alleyway, so it's a little but of water mixed with oil.
Any input is appreciated. =)
