hi need help bought my son a mini brittish open 1275 nearly a year ago for his first car , its done about 50miles in nearly a year, as it sits about for a long time its getting fuel in the engine oil , it now has a bad oil leak with fuel in it , smells of fuel , also has clouds of smoke , what is causing this , is it just because its not getting used or something else, help !
Fuel In Engine Oil
Posted 22 April 2014 - 09:55 AM
Posted 22 April 2014 - 10:09 AM
Has it got a mechanical fuel pump?
If so, it is possible the seal has gone.
Posted 22 April 2014 - 10:11 AM
to be honest i am not sure but think it has, will check this out , thanks
Posted 22 April 2014 - 10:13 AM
Posted 22 April 2014 - 06:19 PM
As mentioned, if it has a mechanical fuel pump attached to the block down the back of the engine, the rubber diaphragm inside the pump can split or perish. This then allows fuel to leak into the engine oil and thin it out.
This can cause oil leaks, but without wishing to startle you, it also makes the car potentially dangerous to drive because of the amount of fuel in the oil. You could possibly end up igniting the fuel/oil mix and cause a "sump explosion" with dire consequences to the engine & gearbox.
It's strongly advisable to get this sorted ASAP and once the pump had been replaced, carry out an oil & filter change!
Cheers, Steve.
Posted 22 April 2014 - 06:33 PM
Posted 22 April 2014 - 06:35 PM
The other issue is, the thinned oil can cause bearing damage etc
Very true Carlos....forgot to mention that bit!!!!
Posted 22 April 2014 - 06:39 PM
I had this, fuel pump was shot as per above.
Posted 22 April 2014 - 06:47 PM
thanks guys , will get on it and change fuel pump, oil and filter , many thanks,
