Check the needle valve around the float area. The needle valve sits in a brass collet. This has a small gauze filter on it. The gauze is prone to catch all the junk, something that actually works!. Unscrew the flat head screw holding the float in. Remove the float making sure you observe how it sits with the jet upon putting it all back together.
You can now takeout the jet and blow it through.. Do not tip the carb upside down as the needle valve will fall out and then it gets lost. Place it on it's side and shake it out into your hand.
Then you can take out the brass collet with a socket. You can then clean the filter. Also look and see if you have a ridge on the rubber of the needle valve. If you do, buy a new needle valve, they come with a new brass collet , filter, seal etc etc as a kit.
You have then just given you carb a quick once over. I f you use the same parts and do not replace anything, when you have put it all back together blow into the fuel inlet and at the same time tip the carb upside down and you should not be able to blow any more, the valve should shut off.
You should replace the rubber seal at the bottom of the float chamber, they compress and it will probably leak when new petrol goes in.
If you need any help, give me a shout 07596 541072
Regards, Neil...........
