Exhaust Keeps Blowing.
Posted 23 April 2014 - 09:09 AM
It's a 998cc mini city with a standard exhaust. The exhaust itself is good with no holes, it's always at the manifold that it blows.
I'm using fire putty to seal it but yet it blows instantly. Should I be leaving it for a certain time to let it set, the instructions just say it should set with heat.
Also how much should I use? Sparingly or liberally?
Posted 23 April 2014 - 09:17 AM
Try changing the engine steadies, on on the block and the other on the gearbox,
And put lots of the sealant on,
If that doesn't help you might have to fit a flex pipe on it
Posted 23 April 2014 - 09:21 AM
Posted 23 April 2014 - 09:29 AM
Posted 23 April 2014 - 09:36 AM
Posted 23 April 2014 - 09:57 AM
Posted 23 April 2014 - 10:06 AM
Edited by RedRuby, 23 April 2014 - 10:06 AM.
Posted 23 April 2014 - 10:38 AM
Posted 23 April 2014 - 10:46 AM
Posted 23 April 2014 - 11:01 AM
I have checked the engine steadies and everything seems pretty tight but am happy to get new bushes after one more attempt.
The clamp is new but was quite cheap so I don't know if that could be an issue.
Can anyone give me advice on how much putty I should use and if I should start it instantly to cure or let it set then just harden it off?
Edited by stevelane, 23 April 2014 - 11:02 AM.
Posted 23 April 2014 - 12:48 PM
Gasket surfaces need to be immaculate or leaks will happen. Use your sense of touch, it'll be more accurate than your eyes in this case.
Posted 23 April 2014 - 12:55 PM
Still not been able to get an answer as to whether I should let it seal or start it straight away
Posted 23 April 2014 - 01:06 PM
Have cleaned up the manifold and the pipe now, not a trace of previous sealant so I'm going to try again.
the exhaust paste usually seals when it warms up and i think the directions on the tins usually say try and fit it after the engine has been running as the exhaust will be warm, iv used a heat gun before to get it to go off and it did work! you need enough to make a good seal, a nice even coating on the mounting face of the joint
if you cant get heat to it then i'd say leave it a few hours before starting
edit* even with it heated i'd leave it a little while just to be sure
Edited by danie garry, 23 April 2014 - 01:07 PM.
Posted 23 April 2014 - 03:45 PM
The exhaust pipe is back on, has now been a couple of hours but am hoping to take the car out tonight so I will give it another hour or so before trying to start it.
I did manage to get under the car and shine a torch up to the manifold before I cleaned it up and there were obvious areas with no sealant so my guess is I started it to early and it just blew the sealant straight out.
The instructions on the packet don't say anything about time, just that it cures when hot.
Let's hope it's worked this time and if not I will get some new bushes for the steadies and try that
Posted 23 April 2014 - 03:51 PM
Thanks for that
i'v had the same problem and nothing at all seems to cure it, its not the best design as theres way to much movement! i ended up butchering the whole lot and welding a slightly larger pipe to the manifold and then clamping the exhaust inside that, new cooper freeflow to go on now!
