Rebuilding An Engine, Is My Shopping List Ok?
11 replies to this topic
#1 Yams
Yams
  • 644 posts
Posted 24 April 2014 - 10:33 AM
I'm going to start buying the parts for my Austin 1300gt engine, and i was just wondering if i'd missed anything out on my shopping list, or there is anything i shouldn't bother getting.
Any help would be great
Main Bearings
Big end bearings
Thrust washers
Gasket sets: Engine gasket set, gearbox gasket set etc
duplex timing chain
Piston rings
Fuel pump: Unsure of what is best, not sure if going to run twin HS4 or HIF44
Fast road Clutch
Clutch Diaphragm, Blue
10 row oil cooler
high capacity water pump, & pulley
Anything i may have missed? I'm more just getting the engine back up and running, opposed to modifying it.
Many thanks
Yams
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 24 April 2014 - 10:35 AM
You would want to replace all the oil gallery and core plugs as well.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 April 2014 - 10:39 AM
Oil pump, maybe cam followers, Plasti-gauge,
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 April 2014 - 10:47 AM
Check and measure bores to see if it need reboring and not rings, same on crank journals
#5 MrBounce
MrBounce
  • 2,660 posts
Posted 24 April 2014 - 11:48 AM
Engine building lube. Torco Cam lube. You should always replace the followers as good practice. What about your cylinder head? That surely should need a look over/valves reground/hardened valve seats done?
See if you can borrow an engine stand - it's a godsend!
#6 HarrysMini
HarrysMini
  • 3,352 posts
Posted 24 April 2014 - 02:51 PM
Yep, cam followers should always be replaced regardless of whether it is a used or new cam being fitted.
#7 Yams
Yams
  • 644 posts
Posted 25 April 2014 - 10:48 AM
Cheers guys, thanks for all your input :)
#8 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 25 April 2014 - 05:30 PM
Don't forget to budget in the machining that might need doing
#9 Yams
Yams
  • 644 posts
Posted 25 April 2014 - 09:14 PM
The engine had done around 50,000 miles. The bores don't look to bad to me, but obviously my eye is, well, 'untrained'.
Would an engine with this millage need to be honed? If so would the honing mean i would need bigger pistons? In an ideal world i do not wish to go up a piston size.
#10 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 25 April 2014 - 09:18 PM
only by measuring will you know if a hone will do or if a rebore is needed, we're talking about very tight tolerances here - not something that can be seen - only measured.
Honing would require just new rings, a rebore would require new pistons and rings
#11 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 25 April 2014 - 09:20 PM
the best way to start with this is to strip, inspect and measure, then you'll be able to start a shopping list/machining list
#12 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 25 April 2014 - 09:23 PM
I think if you're going to all this effort to rebuild it, you should do it properly so it will last. New pistons. County pistons are quite cheap, tt also good quality.
Edited by Stiggytoo, 25 April 2014 - 09:23 PM.
