For Sale – 175 Bhp Rwd Unfinished Mini Project (Toyota Mr2)
No replies to this topic
#1 welshy
welshy
  • 105 posts
Posted 25 April 2014 - 12:00 PM
The VERY reluctant sale of my unfinished RWD 175 BHP Project mini (Toyota MR2 – Mk2 – ACIS version)
The car comes with 95% of the bits required to complete the car. There is a large list of new bits but some of them will need a bit of cleaning up as they were fitted/stored some time ago.
I have taken some quick photos and will add them shortly. Unfortunately I didn’t get chance to clean everything first... there is a lot.
I am after a quick sale, so I am not willing to split the car (although the new parts alone are worth more than the asking price).
In brief:
• New Mini spares 4 Pot Alloy Callipers vented
o New Kevlar Brake Pads
o New Front Braided Hose Kit
o Metro vented discs (rusty but should be recoverable)
• Solid Mount Front Sub frame, professionally shot blasted and painted (offshore grade paint)
• Fully Adjustable Front End
o New Spax Coil Overs
o New Camber Tracking Kit
o New Adjustable Lower Arms
o New Longer Track Rod ends
o New Ball Joints
o Refurbished Upper Arms
o New Timken Wheel Bearings
o New Tie Bush Kit
o New Heavy Duty Tie Rod Ends
• JK composite seats – The padding needs replacing and is available from JK composites
• New 4 Point harnesses – x 2
• Fibre Glass Dash with centre console piece
o The centre console piece is not required due to a fabricated aluminium transmission tunnel
• Aluminium internal panelling/bulkhead
• New – Two Sets of custom Minator (minilite) alloy Wheels 6x13
o Set 1: Have New Yokohama A539 tyres, the front wheels are standard mini 101 PCD and offset (ET16). The rear have a 108 PCD (Ford) with ET23 offset.
o Set 2: Wheels only. The front have 101 mini PCD with ET23 offset and the rear have 108 PCD with ET16 offset.
o Note: one of the wheels is discoloured and will probably need repainting. I cannot remember if it is one with or without a tyre.
• Original 12” minilite wheels with knackered tyres (somewhere)
• Arc Angel Fibreglass flip front
• Two Sets of Arc Angel Sports Pack Arches
• Custom Made Roll Cage/space frame
• The following mini panels have been replaced:
o Heritage Scuttle (with dummy wiper arm holes plugged, filled and primered)
o Heritage A Panels x 2 (not fitted fully)
o Heritage? Front floor panels x 2
o Outer Sills x 2
• New Rear Valance (not fitted)
• Doors will need re-skinning
• Boxes of other bits i.e. lights, loom etc.
• 175 BHP MR2 engine (ACIS version) and gearbox including ALL ancillaries i.e. ECU, exhaust manifold, injection system, drive shafts (CV joints removed).
o These engines I purchased the MR2 complete and stripped it. The engine was running at the time.
• Ford Scorpio Running Gear including hubs, brake Callipers, drive shafts
• MR2 wiring Loom with all of the relevant connections identified, using tie wraps and tie wrap ID characters, as per MR2 wiring diagrams.
• New 4-Off BMW E30 engine mounts
• New Passat/A4/A6 Radiator (slightly dinted)
• Used Rear Protec Ally coil over Shock Absorbers - Non-Mini (these may not be included with the car as a friend is interested)
• Mondeo hand brake cable
• Wilwood Brake Master cylinder kit – single outlet
• Brake master cylinder – double outlet
• Original MR2 Clutch master cylinder
• Prototype rear swing arms with bearing rose joints - (I didn’t like the first attempt and was going to make some more)
• Original MR2 stainless steel tubing which ran the full length of the car connecting the engine to the radiator.
• Westfield type front wheel arches (for inner rear wheel arches)
• All internal panelling is aluminium (ignore the green colour)
I am sure there will be other items which I have missed off.
In total I have spent over £4k.
Only £1500
Free Delivery:
Depending on location (I am in Leeds), I may be able to deliver the car free of charge but will have to remove the engine and front sub-frame.
Please contact me if you have any questions.
Fibre Glass Dash and aluminium  tunnel
MR2 gear linkage
Aluminium Panelling
Seats and MR2 Speedo
Fully adjustable front end, and mini spares 4 pot ally calipers with braided hoses. Unfortunately the fasteners are not zinc plated so have surface rust,  as do the discs.
MR2 wiring loom with all relevant connection cations labelled per the MR2 wiring diagram.
Set of custom wheels with new Yokohama A539'sTires (the other wheels are in boxes)
The engine (aluminium panels removed)
Engine with exhaust manifold
Rear Valance
Two sets of Arc Angel sportspack arches (not the best picture,  I couldn't reach them)
Arc Angels 1 piece fibreglass front
Radiator
One of the rear swing arms which I was going to make again (with bearing rose joints)
More boxes of bits (the harnesses are in there somewhere)
Front section of the roll cage (in red oxygen primer)
Another box of bits with the protec shocks (these shocks might not come with the car)
