Tight Bearings Help Please
22 replies to this topic
#16 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 27 April 2014 - 11:12 PM
Hi guys, another question for you all. Are the inner racers supposed to meet in the middle ? I may just give up and get two sets of gen bearings.
Yes, or depending on type, the extension on the inner racer or the spacer is supposed to be calculated so that bearing is correctly preloaded.
#17 Mrt88
Mrt88
  • 300 posts
Posted 28 April 2014 - 06:42 AM
Morning all,
Does anyone know if the "gen" rear bearings from mini spares are any good ? They don't say timken on them anywhere. I am thinking that I may just get 2 sets and two new hubs.
EDIT:
Guys can anyone confirm what way round the seal should go ? Could this cause the issues ?
Edited by Mrt88, 28 April 2014 - 07:39 AM.
#18 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 28 April 2014 - 08:17 AM
Phone up Somerford minis and just ask for timkin ones, ur doing the right thing mate, I had this problem for days and even had a topic on here, it's the non genuine bearings, I learnt my lesson
#19 Mrt88
Mrt88
  • 300 posts
Posted 28 April 2014 - 02:05 PM
That's exactly what I have just done !
Fingers crossed they turn up and fit straight on.
I will let you know
#20 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 28 April 2014 - 06:01 PM
Hi Theo,
You should be ok with the genuine bearings.
The oil (grease) seal should be tapped in with the solid rubber side facing outwards towards you. The inner edge will be open all the way round with a circular spring embedded into the seal to keep tension on the seal lip and this should face towards the inside of the hub....hope this makes sense!!!
When you tap the seal in, make sure it sits flush with the hub outer rim.
Cheers, Steve.
P.S. keep at it you'll get there in the end!!
Edited by Stevie W, 28 April 2014 - 06:02 PM.
#21 Mrt88
Mrt88
  • 300 posts
Posted 29 April 2014 - 07:49 PM
Hi all,
I just got a set of timken bearings today from sumerford. I did one side tonight. Not only did they tap in great but they greased up sat in place and torqued up like a dream!!
I even went a quater turn to the next pin and I can still turn it with one finger.
Fingers crossed the other side is just as easy.
Thank you to everyone and to you Steve for sticking with me and giving me a tone of advice !!!
Edited by Mrt88, 29 April 2014 - 07:51 PM.
#22 Stevie W
Stevie W
  • 1,204 posts
Posted 29 April 2014 - 08:00 PM
Well done Theo!!!
Your perseverance has paid off big time!!
Glad it went ok tonight and I'm sure the other bearing set will go in a dream too!!
Cheers, Steve.
#23 Mrt88
Mrt88
  • 300 posts
Posted 30 April 2014 - 10:02 PM
It's finally done ! Both the timken bearings went on without a hitch. Slipped on, torqued up and feel totally fine!
Thank you everyone for your help ! I've learnt my lesson about buying imitation parts :-)
Everyone's help is massively appreciated
