carb and inlet manifold for turbo
10 replies to this topic
#1 josh_tacon
josh_tacon
  • 123 posts
Posted 13 June 2006 - 06:22 PM
hi
am i right in thinking you can use a normal hif 44 from a NA engine on a turbo engine if you buy the right kit?
what inlet manifold can you use? a normal one from a NA engine or does it have to be a metro turbo one?
also is it worth spending the extra cash and buying a reconditioned metro turbo hif 44? if i was to do this what inlet manifold could i use?
its going on a 1293 t2 turboed a series (just incase you didnt know!!)
cheers
josh
#2 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 13 June 2006 - 06:29 PM
you can use a normal hif44 converted to turbo spec, which will basically be the same as the turbo one. you can use an na manifold with no problems, but the turbo one was designed for the job and gives more even mixture distribution between cylinders. if youre using the mirage kit (which iirc youre not) its designed to fit an na mg metro inlet
#3 josh_tacon
josh_tacon
  • 123 posts
Posted 13 June 2006 - 06:41 PM
how much is a turbo one worth?
also have they all got that groove on the dashpot or is it only some that have it?
i have seen turbo ones go on ebay without the groove are they wrong?
cheers
josh
#4 josh_tacon
josh_tacon
  • 123 posts
Posted 15 June 2006 - 01:19 PM
did all metro turbo carbs have the groove round the dash pot?
cheers
josh
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 15 June 2006 - 10:46 PM
cheers
josh
Do you mean around the top ? If so, yes, this was where a little clip sat to supposedley hold the dashpot plunger in place.
#6 Leonard
Leonard
  • 784 posts
Posted 16 June 2006 - 11:00 AM
i think he means for the big o-ring to seal it to the main body. i dont know josh, ive only seen one (mine) and that does.
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 16 June 2006 - 12:51 PM
All Turbo carbs are sealed around the dashpot.
#8 josh_tacon
josh_tacon
  • 123 posts
Posted 19 June 2006 - 02:05 PM
i dont really trust the ones i see on ebay as most dont have the groove round the top of the dash pot! although they say they are metro turbo carbs!
i dont want to spend £100s on a carb as theres loads of other bits i need to get and i think money wil start to get a wee bit tight!
what is the best way of doing it? just get a na hif 44 and modding it to be a turbo type or having to splash out loads on a proper turbo carb?
how much would it cost to mod one? is it an easy job you can do at home or is there a lot of machining to be done etc?
cheers
josh
#9 blister
blister
  • 1,008 posts
Posted 17 April 2008 - 10:09 PM
bump
#10 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 17 April 2008 - 10:37 PM
i would say unless you know what you are doing with modifying the carb then your best off buying a turbo one...
#11 Wil_h
Wil_h
  • 3,244 posts
Posted 18 April 2008 - 10:16 AM
All you need to do is buy a turbo repair kit (PM Turbo Phil as he sell them at a good price) and rebuild a standard NA carb to convert it to turbo use, easy. No machining needed.
There is a guide to rebuilding on Turbo Minis here http://www.turbomini...p...vt&tid=2878
There was a guide on how to convert an NA to a turbo, but I can't find it.
