Is My Oil Cooler Okay Like This
56 replies to this topic
#16 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 02:04 PM
Can't go infront of grill oh we'll it's bolted in place now so it's staying out lol
I spent about half hour trying differant places yesterday
And it wouldn't go anynwere due to the hoses
#17 Icey
Icey
  • 1,574 posts
Posted 27 April 2014 - 04:14 PM
Also what the standard oil pressure switch colour of wire I'm sure is black and white
It's white with a brown stripe.
White with a black stripe is for the tach.
#18 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 04:28 PM
Okay cheers
#19 johnR
johnR
  • 2,318 posts
Posted 27 April 2014 - 06:31 PM
You may fall foul of MOT with a cooler mounted in  front of the grill now I'd imagine because of the projections unless you cover the edges?
JohnR
#20 johnR
johnR
  • 2,318 posts
Posted 27 April 2014 - 06:36 PM
Has no-one tried modifying the front panel under the bumper and fitting an oil cooler there, like a Cobra? Would look much neater - have to move the number plate of course.
JohnR
#21 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 07:00 PM
I don't see my car failing an mot with the cooler were it's is now
#22 Alex_B
Alex_B
  • 4,573 posts
Posted 27 April 2014 - 07:03 PM
It wont as it doesnt have any protruding edges
#23 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 07:07 PM
I was guna say there is a fair few things in that engine bay that will do more damage than and oil cooler.
#24 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 27 April 2014 - 07:14 PM
JohnR
It won't, sharp edges or projections have to be from damage or corrosion, user modification isn't an MOT failure in this case.
#25 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 April 2014 - 07:38 PM
JohnR
Yes it is a failure!!
#26 Alex_B
Alex_B
  • 4,573 posts
Posted 27 April 2014 - 07:43 PM
Edit- didnt read properly!
Edited by Alex_B, 27 April 2014 - 07:44 PM.
#27 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 07:52 PM
Why is it a failure then
#28 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 07:56 PM
The cooler don't stick out of the grill
#29 cambiker71
cambiker71
  • 1,050 posts
Posted 27 April 2014 - 08:16 PM
JohnR
20 odd years in the motor trade, ten of them running an MOT station tells me it isn't...
Taken from the inspection manual   http://www.motinfo.g...m4i00000001.htm
Information
The inspection of body condition applies to all vehicles and includes body components such as bumpers,spoilers and mirror housings.
Method of Inspection
Examine the body work for excessive corrosion or damage resulting in sharp edges which are likely to cause injury
Reason for Rejection
A sharp edge or projection, caused by corrosion or damage,which renders the vehicle dangerous to other road users,including pedestrians.
#30 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 April 2014 - 08:32 PM
Well if there is a modification (oil cooler) which has a sharp edge then yes it is a failure as is a damaged bumper
