Is My Oil Cooler Okay Like This
56 replies to this topic
#31 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 27 April 2014 - 08:43 PM
Well if there is a modification (oil cooler) which has a sharp edge then yes it is a failure as is a damaged bumper
You're still wrong, it's only corrosion or damage, not modifications, modifications fail when they affect several things, usually to do with structural areas, but not sharp edges or projections.
 If you get a fail for something like this that you have modified, firstly ask them point out where in the manual it says that modifications are a failure then ask for a copy of a VT17 appeal form if they refuse.
#32 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 April 2014 - 08:51 PM
Ah ok my bad, sorry!
#33 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2014 - 08:52 PM
Something in an engine bag that isn't visible can't be a failure because it might be sharp I'm sure the engine block , dizzy , grill , bumper and front panel will hurt and do more damage than an oil cooler in an event of a crash or a road incident
#34 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 April 2014 - 10:25 PM
oil cooler with no stat? that's going to be a nice healthy engine ;-)
#35 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 28 April 2014 - 05:52 AM
My thoughts exactly.
#36 minilee94
minilee94
  • 3,523 posts
Posted 28 April 2014 - 11:54 AM
Don't need one for a road car
Best to fit one for a race car / track car but road car don't need one
Just Gota door more regular oil changed and filter changes
And on a car that will not get used that often don't matter
Edited by minilee94, 28 April 2014 - 12:01 PM.
#37 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 28 April 2014 - 09:02 PM
so by that logic you don't need one? but hey...if you want oil that never gets to temperature then go for it ;-)
#38 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 28 April 2014 - 09:05 PM
you can lead a horse to water as they say!!
#39 GraemeC
GraemeC
  • 7,467 posts
Posted 28 April 2014 - 09:28 PM
I would say that logic is completely backward - a race/competition car that will see high oil temps most of the time would benefit less from no stat than a road car that will often not get the oil to best operating temp at all, never mind trying to cool it down.
#40 Dusky
Dusky
  • 5,322 posts
Posted 28 April 2014 - 09:30 PM
Please fit a stat for the sake of your engine' s health...
#41 HarrysMini
HarrysMini
  • 3,352 posts
Posted 28 April 2014 - 09:36 PM
Who told you this?
#42 smartie93
smartie93
  • 285 posts
Posted 29 April 2014 - 09:53 PM
Has no-one tried modifying the front panel under the bumper and fitting an oil cooler there, like a Cobra? Would look much neater - have to move the number plate of course.
JohnR
That's pretty much how they're mounted on the miglias, they have their own little scoop and everything :) surely you can run with a numberplate to one side like an Alfa
#43 Alex_B
Alex_B
  • 4,573 posts
Posted 29 April 2014 - 10:03 PM
I am afraid that is correct with your logic being backwards, the purpose of an oil cooler stat is to avoid the oil being overcooled, this is seen when the engine is run from cold or in colder climates. For the oil to work at best efficiency it should be hot, if it was too cold you will end up with oil which is thicker than it needs to be (reducing engine power due to the oil pump taking more power from the engine to pump) whilst also suffering for the all the symptoms associated with running the engine cool.
Race engines will tend to only be run at idle when stationary (where heat soak will occur) or at full chat when racing round a track, as such the stat isnt required as the engine is only ever running hot, on a road car a stat is vital
#44 minilee94
minilee94
  • 3,523 posts
Posted 30 April 2014 - 11:20 AM
If I'm so wrong in this have a chat to Steve at med who builds race engines and road going engines for a living
Also have never fitted a cooler with a stat to any engine including there race lumps they do
Edited by minilee94, 30 April 2014 - 11:27 AM.
#45 Alex_B
Alex_B
  • 4,573 posts
Posted 30 April 2014 - 11:27 AM
If I had more free time and didnt have multiple assignments due then I would as I cannot believe someone who builds performance engines is recommending running without a themostat of some kind in the cooler!
