Pre Filling Oil Filters
27 replies to this topic
#1 Cambelt
Cambelt
  • 158 posts
Posted 26 April 2014 - 10:17 PM
What are your opinions on pre filling the oil filter before fitment is it worth doing or not ?
#2 miniyellowmini
miniyellowmini
  • 595 posts
Posted 26 April 2014 - 10:21 PM
I don't normally, it'll fill soon after it's started anyway. Do put a smear of oil on the seals though
#3 Cambelt
Cambelt
  • 158 posts
Posted 26 April 2014 - 10:25 PM
Yeah I will make sure to do that my dad does it on his but that could be because it's a bigger filter on a big Diesel engine thanks for the reply
#4 geoff-d
geoff-d
  • 468 posts
Posted 26 April 2014 - 10:26 PM
Disconnect the coil and crank the engine over until you have pressure or the oil light go's out then connect coil & off you go.
#5 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
I do but you have to make sure you dont then over fill the engine itself.  Smear of oil on the seal is always recommended too.
#6 Cambelt
Cambelt
  • 158 posts
Posted 26 April 2014 - 10:29 PM
Thanks for the advice gents don't think I'll bother filling it and just disconnect the coil like you said thanks again
#7 robminibcy
robminibcy
  • 1,516 posts
Posted 26 April 2014 - 10:39 PM
I always fill mine, it just helps to get oil flowing faster when you first crank rather than waiting for the filter to fill before any oil gets to the engine. I wouldn't think it would matter on a used engine though as there will be some residual oil but I wouldn't want to do it on a new build.
#8 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 26 April 2014 - 10:44 PM
Don't really see the point in this to be honest, it will build up pressure pretty quickly anyway as the engine will not be completely empty. All you'll do is fill the bores with petrol, accelerating engine wear..
I usually fill it, however on our modern cars that I work on, I don't, as it's all spilled out by the time you've got it where it goes.
Edited by HarrysMini, 26 April 2014 - 10:45 PM.
#9 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 26 April 2014 - 10:47 PM
I always fill it
#10 Gremlin
Gremlin
  • 2,142 posts
Posted 26 April 2014 - 10:48 PM
Why would you not fill the filter? When you run the engine normally and let it cool then check the oil level, the filter stays full, so its not like your adding any
#11 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 26 April 2014 - 10:54 PM
I have always make a practice of filling the oil filter.  Only takes a minute, you know there is oil in the system and oil is the cheapest insurance you can buy.
Bob
#12 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 26 April 2014 - 10:55 PM
I fill mine, but then I have the spin on type that fits on a housing. Obviously this will not work if you have an A-series with the oil filter mounted to the block, or an early one with the paper filter and canister.
And as Harry says, why would you turn the engine with the coil disconnected and potentially wash your bores with petrol!
#13 sledgehammer
sledgehammer
  • 3,108 posts
Posted 26 April 2014 - 11:00 PM
I always fill it - unless it is sideways or upside down (rare) & always oil on seal & thread
I also crank engine till oil light goes out , then pull choke out as required
otherwise you can have the risk of the ends barking
#14 surfblue
surfblue
  • 1,827 posts
Posted 27 April 2014 - 09:08 AM
I have always filled oil filters on every car that I ever worked on - including my current mini with canister and paper element. I just have it assembled with bolt and rubber sealing washers, spring and plate in place, drop the canister in and fill, then offer up to housing and tighten bolt. Fiddly but not impossible.
#15 davej
davej
    Kelly Jones
  • 985 posts
Posted 27 April 2014 - 09:14 AM
I have always filled mine with a smear across the rubber seal.
