I don't know if I have installed it incorrectly, but I'm sure this can't be normal for it to be touching the fuel line. I have attached a few pictures to make it easier to understand what I am talking a about. Any help on wether it is a common problem or anything be appreciated. Thank you.
Lcb Exhaust Too Close To Fuel Line
Posted 26 April 2014 - 10:18 PM
Posted 26 April 2014 - 10:23 PM
That looks like the battery cable to me ? . If so that is common . When it gets hot it melts the plastic cover off then it's a dead short so could catch fire if you are unlucky. So you need to rerun the cable away from the hot exhaust.
Posted 26 April 2014 - 10:25 PM
thats the brake lines and battery cable, mine is quite close to it but not tuching it, mine battery cable has just been cabletied up out the way of it.
Posted 26 April 2014 - 11:17 PM
As I'm sure you already know - don't use it like that - a battery cable touching exhaust will short circuit quickly
it needs re-routing away from the exhaust
I would also check (if you have a manual fuel pump) , how close the pipe is to the exhaust in that area
best of luck
Posted 27 April 2014 - 12:04 AM
I will check the area of the fuel pump, as that is a good point well mentioned thank you sledgehammer. Cheers people.
Just one quick question to add - the y piece is a bastard to line up and the single pipe furthest away from you looking at my pictures, does not want to push on as far as the opposite side, if you look closely you can see the difference in gap in the split. just wondered if this is common also ? Thanks.
Edited by MayfairEdition, 27 April 2014 - 12:09 AM.
Posted 27 April 2014 - 07:55 AM
Posted 27 April 2014 - 08:01 AM
Shorted so hot the battery terminals.melted and the earth cable @ battery melted too
Posted 27 April 2014 - 09:31 AM
My maniflow was the opposite and the two pipes for the y piece were too close together, make sure u wire brush and sand a little so all the pipes for on easily, and it's a car of brute force and ignorance to try and pull then together and slide the y piece on
As long am I'm not the only one sweating away trying to line them up then eh! Makes me feel better lol. And after all these "I've melted my battery cable" comments I think ill just cable tie it out the way somewhere. Cheers
Posted 27 April 2014 - 10:32 AM
