Swapping Air Box To An Air Filter (Pod)
11 replies to this topic
#1 TheJack
TheJack
    Formally known as Jackocola
  • 531 posts
Posted 28 April 2014 - 06:05 PM
Just wondered how to swap the big air box to a air filter/pod? I have seen a few mini's with it in but not to sure if it is as easy as it sounds! :P
#2 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 28 April 2014 - 06:13 PM
Do you mean fitting a KnN filter?
#3 TheJack
TheJack
  • 531 posts
Posted 28 April 2014 - 06:14 PM
Yeah!
#4 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 28 April 2014 - 06:30 PM
You'd be better to fit a stage one kit, http://minispares.co...ge one kit.aspx
This replaces the inlet manifold and full exhaust system... 20% increase in power after a rolling road session
#5 TheJack
TheJack
  • 531 posts
Posted 28 April 2014 - 06:33 PM
I have been looking at one of them, posted on forums about swapping the exhaust and manifold, I looked at the half stage one and then you just add the exhaust which I found handy! Only problem is where to go for a rolling road session, I know Mini Sports do them but that is all the way up North!
#6 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 28 April 2014 - 06:34 PM
What region are you in? Then google :)
#7 TheJack
TheJack
  • 531 posts
Posted 28 April 2014 - 06:40 PM
Somerset :P do they tune at any rolling road or is it just to see the difference in power?
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 28 April 2014 - 07:08 PM
They will set the carb up so its running right. Will help with power but also stop the engine from lunching itself if the fuelling is way off after the parts swap.
#9 TheJack
TheJack
  • 531 posts
Posted 28 April 2014 - 07:09 PM
Ah right, so I can go to any rolling road and they will do it?
#10 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 28 April 2014 - 07:10 PM
Here http://www.nemotors.co.uk
Or http://www.rawlesmot...uk/contact.html
#11 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
You can but best to check on here if anyone else has been. Some are more mini friendly/ capable than others.
#12 TheJack
TheJack
  • 531 posts
Posted 28 April 2014 - 07:11 PM
The first one seems alright and it is the closest!
I will have a look!
