Best Answer Cooperman , 28 April 2014 - 06:41 PM
Get a piece of fine emory cloth and make sure the edges are not sharp. Polish our the damage without abraiding the lobe surface.
The follower runs clear of the edges of the lobe so it won't be a problem.
Go to the full post
Posted 28 April 2014 - 06:36 PM
Posted 28 April 2014 - 06:41 PM Best Answer
Posted 28 April 2014 - 06:49 PM
Ah! Thanks Coop! Ok - will 400 emory cloth do?
Posted 28 April 2014 - 07:03 PM
Posted 28 April 2014 - 07:05 PM
As Cooperman says, you'll need to make sure there are no sharp edges to the little dink, as any sharp edges/corners are stress raising areas, which means that cracks will form much more easily from these points than anywhere else. Obviously a crack would eventually lead to total failure of the cam and it would snap in half in an extreme case. ![]()
Edited by The Otter, 28 April 2014 - 07:13 PM.
Posted 28 April 2014 - 07:11 PM
You would be most unlikely to snap an A-series cam, although the damage must be smoothed out. But, do not let the emory cloth touch the cam lobe surface anywhere, just abraid down the slight area of damage so that there are no sharp edges. If you have a small circular draw-file you could use that first, then finish off with the emory.
It'll be fine, don't worry about it.
Posted 28 April 2014 - 07:54 PM
Thanks everybody! I´ve already smoothed it down and reinstalled the cam (after cleaning it ofcourse...).
Was a bit nervous there - but thanks to the almighty knowledgebase on this forum I can now safely go to bed... ![]()
Posted 28 April 2014 - 07:58 PM
Sleep well and think about driving flat out along a narrow country lane in your mighty Mini
Posted 29 April 2014 - 06:18 AM
Use an oil stone, much better.
Posted 29 April 2014 - 08:24 PM
Hmm... when I posted this topic I also sent the pics to Swiftune, with the same question.
Got a mail from them today:
We have examined your pictures and if we were building an engine we would not fit the cam, the damage is at the point of most load.
Sorry we cannot advise different.
More confused now... ![]()
Posted 29 April 2014 - 08:30 PM
Posted 29 April 2014 - 08:36 PM
Posted 29 April 2014 - 08:38 PM
Posted 29 April 2014 - 08:39 PM
Posted 29 April 2014 - 08:41 PM
Why not weld a small blob of weld, then emery cloth it back? Or am i being silly?
No, just take Coopermans advice.
Don't start welding bits on, it wont end well
