Did I Destroy My Sw5?
Best Answer Cooperman , 28 April 2014 - 06:41 PM
Get a piece of fine emory cloth and make sure the edges are not sharp. Polish our the damage without abraiding the lobe surface.
The follower runs clear of the edges of the lobe so it won't be a problem.
Go to the full post
31 replies to this topic
#16 Gremlin
Gremlin
  • 2,142 posts
Posted 29 April 2014 - 08:44 PM
Why not weld a small blob of weld, then emery cloth it back? Or am i being silly?
The latter, it's only affected about 1mm^2 so far, you weld a bit on and by the time you got it down close to the profile you'll end up affecting a lot more of the lobe, and I don't know if it would beyond reason to weld it up and send it to swiftune to put it in the grinder and take it down to perfect?
#17 Alex_B
Alex_B
  • 4,573 posts
Posted 29 April 2014 - 08:56 PM
Welding would be a very bad idea! it would affect the heat treatment of the lobe at the very least
#18 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 29 April 2014 - 08:58 PM
It's find as is follow the advice of Cooperman. Welding will wreck it!
Ac
Edited by ACDodd, 29 April 2014 - 08:59 PM.
#19 Gremlin
Gremlin
  • 2,142 posts
Posted 29 April 2014 - 08:59 PM
Are they heat treated?
#20 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
True!
#21 Dusky
Dusky
  • 5,322 posts
Posted 29 April 2014 - 09:01 PM
If you really want to I think you can use a kind of filler that head porters use... its made to withstand the vibrations,turbulation and temp of a cylinder head's exhaust port so...
#22 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 29 April 2014 - 09:03 PM
Erm no!
Ac
#23 Alex_B
Alex_B
  • 4,573 posts
Yes! its one of the highest wearing parts of the engine
#24 Gremlin
Gremlin
  • 2,142 posts
Posted 29 April 2014 - 09:06 PM
Hmm
#25 Dusky
Dusky
  • 5,322 posts
Posted 29 April 2014 - 09:26 PM
Erm no!
Ac
I.dont know, maybe it would.fly off,but it.probably wouldnt damage anything and he would sleep good lol
#26 Magna-Flash
Magna-Flash
  • 78 posts
Posted 30 April 2014 - 03:41 AM
OK, guys - I think you´re right! Swiftune couldn´t have said anything other than they did - they want to be sure AND they want to sell another cam.
I´ll stick with this cam - and if anything fails, so be it...
Thanks again...
#27 Gremlin
Gremlin
  • 2,142 posts
Posted 30 April 2014 - 06:00 AM
Good man, the worst thats going to happen is that your going to destroy the follower - not a disaster
#28 Dusky
Dusky
  • 5,322 posts
Posted 30 April 2014 - 06:55 PM
broken bits inside an engine? Nah no problem.. :P Worst thing that could happen is a camshaft that breaks, I saw one in my shor tlife ( only 17 years old) and it was a disaster..
#29 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 30 April 2014 - 07:02 PM
I've seen the results of a cam follower wearing unevenly - it enlarged the bore and gradually canted over.  Ended up paper thin and rattling round.
If it had been a normal block it would have been scrapped, but as it was a 1070S engine the cam followers were rebored to MGC size and saved.
Edited by Vipernoir, 30 April 2014 - 07:03 PM.
#30 Cooperman
  • 23,513 posts
Posted 30 April 2014 - 08:33 PM
How many times? Just linish the damaged area to remove any sharp edges, polish it back without touching the outer lobe surface and it'll be fine.
Start welding, filling with plastic putty or otherwise bu******g about with it and you might as well just scrap it.
It is NOT a problem.
