Well i have recently installed a aldons electronic ignitor into my 1275cc mini.
The engine:
standard engine 1996 converted back to carb (hif44)
lucas sport coil
aldon yellow distributor
aldon electronic ignitor
sportex exhaust
lcb manifold
Pancake jr racing filter (K&N Style)
When i installed the ignitor the engine started right up. We then checked the timing and it was about 13degress and advancing correctly. I then ran the mini for 3 journeys in that day one about 10miles and the other 2 about 6miles. I then parked up the mini for the night. I then went to go start it in the morning and it fired on choke straight away but then died, and would not fire again. i then decided it must be a fuel issue and checked it was getting into the carb and it was with good pressure. I then checked the spark on all 4 cylinders and it is healthy and strong. I am lost for ideas any help would be appreciated. I need to done before london to brighton PLEASE!!!!!!!!
Side note, it will fire when brake cleaner is sprayed into the filter which is a pancake jr racing one.
