Led Indicators - Both Sides Flashing
11 replies to this topic
#1 chipmongrel360
chipmongrel360
  • 103 posts
Posted 29 April 2014 - 08:59 PM
1983 mini city
So i fitted led flasher boards in place of indicator bulbs on the mini, and replaced the two relays with 2 pin, 12V LED relays. The problem is that when I indicate one way, all four lights come on but one side (the direction i'm indicating in) is a bit brighter than the other side.
What could be causing all four to come on at once?
It's these lights from spiyda design https://www.spiyda.c...led-lights.html
Cheers, Chris
Edited by chipmongrel360, 29 April 2014 - 09:23 PM.
#2 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 29 April 2014 - 09:07 PM
Your links bad.  I'd ask Spyda design first though KernowCooper might well have an idea.
#3 Icey
Icey
  • 1,556 posts
Posted 29 April 2014 - 09:08 PM
In the standard loom the only places the two sides come together is at the indicator stalk and the hazard switch, has this affected the wiring for those?
On a side note - I really need to work out a way of building my LED units on an industrial scale. If they can charge ~£100 for those, I'm laughing! Interesting to see what they look like fitted though, any pics?
#4 chipmongrel360
chipmongrel360
  • 103 posts
Posted 29 April 2014 - 09:27 PM
I e-mailed spiyda back when I first attempted to fit them, about a year ago, and the only help they could offer was an indicator wiring diagram.
The only thing changed in the loom was the relays, wiring should be fine, the indicators work as they should when using standard bulbs and normal relay.
haha yes they are fairly pricey, I shall get some pics up tomorrow
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 April 2014 - 09:37 PM
did you just fit the relay into the existing plug or check that the pins on the relay do the same job as the one you replaced ?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 April 2014 - 10:10 PM
They use a 3 pole relay if I'm not mistaken and should be marked B49 49a and E31
So if you just wire up the 2 wires off a flasher unit the new relay needs a extra earth wire
In accordence with the Din wiring numbering
49 is 12v input
49a is  output
31 is earth
The leds you have are the domestic ones for single filiment replacement and have one single centre pin not like a side/brake light bulb, with 2?
Edited by KernowCooper, 29 April 2014 - 10:18 PM.
#7 Icey
Icey
  • 1,556 posts
Posted 29 April 2014 - 10:11 PM
The LED bulbs/units shouldn't cause a problem as they are on isolated sections. I would suggest, as Bungle wrote above, the relays are likely to be the cause.
What happens if you run it with the standard relay (it'll flash far to quickly or slowly but at least you'll have eliminated something)?
Edited by Icey, 29 April 2014 - 10:15 PM.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 April 2014 - 10:15 PM
Is it a centre clock car?
#9 chipmongrel360
chipmongrel360
  • 103 posts
Posted 30 April 2014 - 02:39 PM
I only managed to get 5 minutes to look at it today
Things got strange, the lights stay on solid with the standard relays, but all four are still on, suggesting the led boards are the issue, would it be possible one board could be shorting off the car and causing this?
It is indeed
#10 chipmongrel360
chipmongrel360
  • 103 posts
Posted 30 April 2014 - 02:42 PM
pins are the same in both
49 is 12v input
49a is  output
31 is earth
so a 3 pin with ground wire would most likely be needed to get them working as they should?
the leds are definitely indicators yea, not for brake lights.
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 April 2014 - 07:43 PM
If they are din marked as my post yes they do need a earth wire
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 April 2014 - 10:02 PM
Unplug the repeater on the clocks, it'll stop the problem. You need to arrange it to have 2 repeaters at the dash instead of a common one, or else use an electronic flasher with a dedicated repeater output that will run the single lamp.
