Mini 30 Misfire
10 replies to this topic
#1 mini-me91
mini-me91
  • 196 posts
Posted 29 April 2014 - 10:24 PM
Can anyone advise me on what may be wrong with this mini? Iv changed points, changed plugs, iv put lights on the plug and they all light up when running. It idles fine but splutters and struggles when driven, I think it may be vacuum advance or head gasket, has anyone else had this problem?
#2 smartie93
smartie93
  • 285 posts
Posted 29 April 2014 - 10:29 PM
Maybe a fuelling issue? Has it got dashpot oil?
#3 mini-me91
mini-me91
  • 196 posts
Posted 29 April 2014 - 10:31 PM
I'm sure its fine for fuel, it has oil in dashpot and I have tried setting mixture too with no success
#4 smartie93
smartie93
  • 285 posts
Posted 29 April 2014 - 10:39 PM
Change the oil for piece of mind, mine sputtered and wouldn't pull below 4000 because the oil was too thin. Is the needle correct? Is the ignition timing correct?
#5 smartie93
smartie93
  • 285 posts
Posted 29 April 2014 - 10:42 PM
You can check the vacuum advance with a timing light: suck on the end of the hose, if the timing is unaffected you have your problem
#6 mini-me91
mini-me91
  • 196 posts
Posted 29 April 2014 - 10:45 PM
The oil in it is engine oil not sure if that would matter? The needle is aau which I believe is either 998 or stage 1 if I remember right? I believe the timing is correct I will check it though just to be sure
#7 mini-me91
mini-me91
  • 196 posts
Posted 29 April 2014 - 10:46 PM
Thank you for advice about vacuum advance will definitely be trying that :)
#8 smartie93
smartie93
  • 285 posts
Posted 29 April 2014 - 10:48 PM
Engine oil should be fine :) Did you do anything just before it started playing up?
#9 mini-me91
mini-me91
  • 196 posts
Posted 30 April 2014 - 07:13 AM
It has stood for about 4 years but it has been started like every 2 months, just didn't have the time to work on it
#10 mini-me91
mini-me91
  • 196 posts
Posted 30 April 2014 - 12:55 PM
Checked the advance and there is no resistance, there is a vacuum at the carb though so I know that is fine
#11 smartie93
smartie93
  • 285 posts
Posted 30 April 2014 - 09:55 PM
No resistance,as in you suck and have to keep sucking? The diaphragm therefore can't hold a vacuum and is broken meaning you have no vac advance. I don't know if this would cause the problem you mentioned. I drove round with no vac adv while waiting for a new pipe and it was only a bit sluggish under partial load :/
