This is really to those electricians out there.
Please could someone tell me the journey that takes place - cable-wise - when you push the indicator stalk forward to light up the main beam?
This is on a late pre-ignition mini (rad on the side, no steering wheel cushion).
I've been rewiring many parts of my mini because it had a whole host of electrical issues and I've introduced a cbs-online fuse control board (I highly recommend) which takes over from the 4(?) fuse holder on the bulkhead. It's a project that is taking ages but I've introduced a few luxuries on the way.
When I pull back on the stalk the main beam works but push forward and it doesn't
You can clearly see the contacts are different in the switch.
Firstly - does it involve the 'blue only' cable? second - does the blue wire carry +ve to the switch in the stalk or does it carry it away when the switch is activated?
This has really stumped me because the main beam side of things has been working until recently and I haven't changed anything!
Does main beam use an inline fuse or one of the fuses on the old box of fuses (on the bulkhead)?
One thing to note - the contacts to the indicator stalk were loose and became disengaged so there's a possibility that I connected something back on wrongly but I highly doubt that due to how each connector 'hung' against the stalk (i.e. despite it being disconnected they've been in that position so long that they sit facing 'their' pins).
Usually when you flash your lights both filaments light up (if you normal lights are on). When you put main beam on via the switch it turns off the normal beam. Is there any issue with both filaments lighting (i.e. normal and main) when switching main beam on? (I'm thinking of workarounds as well as trying to fix it as it should be).
So - apart from those details what I would really like to know what happens when you push that stalk forward (i.e. how the circuit works).
Any help would be brilliant
cheers
