Temp Gauge Problem
13 replies to this topic
#1 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 30 April 2014 - 05:06 PM
My temperature gauge moves but doesnt move out of the cold bit. When i ground the wire it shoots up so it is working, i have also replaced the sender, what else can it be?!
#2 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 30 April 2014 - 05:08 PM
That its not getting that hot?
Is the thermostat stuck open?
#3 Moggyton
Moggyton
  • 1,152 posts
Posted 30 April 2014 - 05:20 PM
I ran it for a good half an hour and its a new thermostat too.
#4 Austin mini 30
Austin mini 30
  • 332 posts
Posted 30 April 2014 - 05:21 PM
I had exactly the same problem- replaced the temp sender as you said but also replaced the thermostat, flushed the cooling system and it is great!!.
#5 Moggyton
Moggyton
  • 1,152 posts
Posted 30 April 2014 - 05:25 PM
Replaced the sender and thermostat, so i guess i need to flush the radiator
#6 Austin mini 30
Austin mini 30
  • 332 posts
Posted 30 April 2014 - 05:27 PM
I would. I was replacing my heater matrix at the time and thought i may as well clean it all out and sort the temp gauge whilst i was at it. hope it comes to life soon!!!
#7 clubman1976
clubman1976
  • 23 posts
Posted 30 April 2014 - 06:01 PM
Did you try the new thermostat in some hot water first to make sure it works? Don't write it off as an issue just because its new!! :-)
#8 Moggyton
Moggyton
  • 1,152 posts
Posted 30 April 2014 - 06:07 PM
Should i just drop it in some boiling water?
#9 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 30 April 2014 - 06:19 PM
Yes, boil the kettle (large mug will do) and drop it in, it should open instantly!
#10 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 30 April 2014 - 06:22 PM
Put the thermostat in a pan with room temp water with a thermometer and bring the temperature up so you can tell if it's opening at the rated temp. If you drop it into boiling water it will only tell you that it opens at 100 degress C. What you're trying to find is it opening at the correct temp which can be 75C, 82C, or 88C which are the common temp thermostats for minis. If you still have the box or know which one you bought it should open at that temp, conversely it is stamped in some of the thermostats on the end.
Edited by bikewiz, 30 April 2014 - 06:25 PM.
#11 Moggyton
Moggyton
  • 1,152 posts
Posted 30 April 2014 - 06:23 PM
Yeah i recently put a 82 in.
#12 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 30 April 2014 - 07:33 PM
So you should check to see if it opens at 82C if it opens at a lower temp you may have found your problem.
#13 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 30 April 2014 - 07:56 PM
Is yours a SPi? I had issues on one with the pipe that comes off the thermostat housing (on the sandwich plate iirc)... It was blocked with crud
#14 Moggyton
Moggyton
  • 1,152 posts
Posted 01 May 2014 - 06:35 AM
Carb.
