What width and offset wheel should I be looking at to run archless?
Some example wheels and set ups would help thanks (10" wheels only)
Posted 30 April 2014 - 05:06 PM
Posted 30 April 2014 - 05:12 PM
what brakes ?
Posted 30 April 2014 - 05:14 PM
7.5 cooper on the front and i have the choice of spacered and non spacered on the rear
Posted 30 April 2014 - 08:38 PM
Standard Cooper 'S' offset on 4.5" wide with normal 'S' spacered drums on the rear.
The size is as Mini Spares part number C-21A1968.
Posted 30 April 2014 - 08:43 PM
What about 5" wide such as D1s?
Posted 30 April 2014 - 08:53 PM
I think the D1 has approximately 1" greater datum offset, so an arch extension will be needed. Never seen D1's without arch extensions.
You need the same offset as the original Mk.1 Cooper 'S' steel 3.5" or 4.5" wheel. The D1 has what used to be called 'reverse rim' offset and they could be used on the 850 with drum brakes.
