image.jpg 33.36K
4 downloads
Posted 30 April 2014 - 06:46 PM
image.jpg 33.36K
4 downloads
Posted 30 April 2014 - 06:49 PM
They dont tend to work all that well if the heat sensing spring inside is old (its a service item) and I dont know if you can get that part any longer
Incidentally I am running without one on my 998 and I only need a little choke to start, I would ensure the choke is set up correctly so the first portion of it operates the fast idle cam then enrichens the mix
Posted 30 April 2014 - 06:54 PM
Also check your thermostat. If you're running a 78 or 82, try an 88.
i might have a good one in one of my boxes if you want me to look?
Posted 30 April 2014 - 07:02 PM
Posted 30 April 2014 - 07:12 PM
Okay guys thanks and yes ToM 2012 if you could look that would be great! Would a k&n pancake filter or cone filter work any better than my original round box?
The standard airbox is better for performance than both the alternatives mentioned, how that affects cold starting i dont know, I doubt it will help however!
Posted 30 April 2014 - 07:35 PM
ile take a look for you tomorrow as i need to pop garage. its not going to be brand new all shiney and etc its been used but still reusable..
Posted 30 April 2014 - 07:46 PM
